Passenger side mirror tilt function in '09 GL550?
Thank you in advance!
Happy New Year,
Lance
The Mirror Curb-Tilt Feature is activated by shifting into reverse and selecting the right mirror button on the drivers door. You can then adjust the position of the mirror to see the right rear tire. This allows you see exactly where the curb is when parallel parking to avoid scuffing the tire sidewalls or wheels. When you place the vehicle in Drive the mirror resets to its original position. The Curb-Tilt position is saved so every time you shift to reverse it adjusts to the same position. To turn the feature off shift into reverse and press the drivers mirror button. The mirror will return to it's original position.
This Feauture however needs to be enabled in one of the command menus. The dealer should be able to help you with that.
Thanks,
STP
My build sheet has the following mirror related build codes:
249 INTERIOR AND EXTERIOR MIRROR,AUTOMATICALLY DIMMING
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
500 ELECTRIC FOLDING OUTSIDE MIRROR
P49 MIRRORS PACKAGE
