22 Inch Tires
Old Jan 12, 2011 | 06:56 PM
PurpleHaze's Avatar
08 S550 and 07 GL450
22 Inch Tires
Whats the best size to run with a 22 inch setup? I've heard 295/40/22, 285/40/22 and even 305/40/22... I think 295/40/22 would possibly be best, but interested to hear what others are running as well as pro's and cons of each.
Old Jan 12, 2011 | 07:27 PM
LEOSOPHIE's Avatar
GL550
All of the tires you are considering are going to have a 3-4 % speedo error. The gl550 combination is 295/40x21 with a diameter of 30.3 which is the same as the other GL models. The tires you mentioned have diameters of 31.3, 31.6. and 31.1.
Old Jan 13, 2011 | 07:27 AM
psoas's Avatar
09 jeep srt8, 07 gl450
The factory tires offered on the gl450-550 range in size from 769mm o.d. (gl550) to 785mm o.d. on the gl450 with the 19 tire option...so even the factory set ups are not all going to be exactly the same.
Per Bigwheels.net, they have a nice page that shows the overall diameter of each tire you are looking at.
The widest tire that fits in that range of overall diameter is a 305/35-22 at 772mm high, but it only comes in the pirelli scorp at $311 per tire (back in 07 they we around 450 per tire!). This will look really good, especially if you are lowered a few inches!
After burning thru a set in 19k miles, I opted for a 305/40-22, overall diameter 803mm. This size is very common and very inexpensive. You will have much more choice in tread pattern and tread compound as well.
I would recommend a 305/40/22...if you are on a 22X 9-10 inch wide rim with a off set of ~48-55et.
I money is no concern and you don't encounter snow, get the 305/35/22.
Old Jan 13, 2011 | 10:29 AM
LEOSOPHIE's Avatar
GL550
This tire is much closer to original diameter but he didn't mention going that low aspect ratio.
Old Jan 13, 2011 | 12:17 PM
psoas's Avatar
Ultimately, these trucks are not that specifically tuned with respect to tire overall diameter (assuming the same from front to back). We are talking full 15 mm in difference from one factory tire to another. Plus you could have a 10mm drop just from low tire pressure, and the truck will still run just fine.
Your speedo will be off a little...3% at 60 mph is 1.8 mph is certainly not life altering.
Which rims are you looking at?
Old Jan 13, 2011 | 12:38 PM
LEOSOPHIE's Avatar
GL550
A benefit is extending your warranty by 3% but don't get caught speeding in CA as Gov Brown is raising fines and enforcement to tackle our deficit.
Old Jan 14, 2011 | 02:40 PM
PurpleHaze's Avatar
anyone have pics of a gl with the 305/35/22 or 305/40/22? I currently have 295/40/22 on and its time for new tires and the only option is Michelin latitudes
Old Jan 16, 2011 | 02:49 PM
Taylormade's Avatar
2011 GL450, 2009 BMW 550i
Go to 1010tires.com and use the tire size calculator. You'll see that the 305/40 22 results in a speedometer difference of only 2.263% which is not of any significance. The 285/40 22 provides the closest diameter to the OEM tires and only has a speed difference of only 0.223%.
I went with 295/40 22 because I wanted the Michelins. If not, I would have gone with the 305/40s. I would have been concerned, however with putting the 305s on a 22x9 rim. The installer said it would have been fine though.
I wouldn't go with the 305/35 because they will result in you odometer ticking off miles faster than it should.
Old Jan 17, 2011 | 02:37 PM
psoas's Avatar
305/35-22 overall diameter is 772mm
295/40-21 overall diameter is 769mm (stock on gl550)
so the 305/35 will not change your speedo "any more" than putting on a set of oem gl550 rims/tires....fyi
Old Jan 17, 2011 | 03:02 PM
Taylormade's Avatar
Psoas, the OP is talking about the GL450, not the 550. They aren't the same diameter. The diameter of the OEM tires on a 450 is 785mm and as you already stated, the 550 OEM tires are 769mm in diameter. If the OP had a 550, then the 305/35 would make sense.
For every 100 miles of actual driving distance, the odometer will have an added additional 2 miles if you used the 305/35 on the GL450. This makes no sense.
Old Jan 17, 2011 | 07:19 PM
psoas's Avatar
I guess I never considered the error in mileage, but that would really push me toward the 305/40-22. They are cheaper and your car will not go out of warranty as fast!
Old Feb 14, 2011 | 04:26 AM
accessdenied's Avatar
GL450
305/40/22 on 22x9
Hi, the rims I wanted to buy only comes with 22x9 and 22x10.5 (here's the link to the wheels I want http://bit.ly/emIqWj) . I wanted 305/40/22 on them but America's Tire said to just use either 285 or 295. the 295 is very expensive. 305 is cheaper than 285.
Who told you about not putting 305's on 22x9? You also mentioned that installer says ok with it? I think offset of the rims is +35.
Thanks.
Old Feb 14, 2011 | 03:02 PM
psoas's Avatar
I am right at the edge of the front fender now with 305/40's on 9.5 et 48 rims.
If you go with the 9's at et35 you are going to be 9mm beyond the set up on my truck.
All depends on the look you are thinking about.
