Gl320 cdi 2007 ( bad year or bad luck?)
Are these normal complaints with this model or did I get the proverbial made in on a Friday! (I think in Mexico)... Ugh
Now, ask Tam or myself and you'll get a story of problems. But one thing about mine is, once a problem is fixed it has stayed that way (and yeah, I've had a few). And Tammy? She had a 2010 with so many problems it streched credulity, and she's well in to the buyback process, with Mercedes recognizing the vehicle is faulty.
I did realize that the truck was manufactured in the US, I was just trying to be humerous about the whole situation. Always better to try and find humor in some of lifes annoying bumps!
Thanks again for your imput.
Add me to the list of those with problems. My MY08 GL 320 CDI had several electrical problems including air shock and tailgate issues causing dead battery situations three separate times (you can find my posts on this board). The problems were eventually fixed. However I traded for the MY 11 Bluetec for more convenience features such as updated Nav, and Keyless Go and the bi xenon headlights and cool LED driving lights. I have had the new GL for only 3 months and 4K miles. No issues as of yet. However, I would say after reading about this new V6 turbo diesel in the diesel forums, it is not your typical "long life" diesel. It is not rebuildable. And any time you turbo an engine, you are effective shortening its useful life. That being said, I only intend to keep the GL while it is under warranty as I don't think I could afford to keep it beyond warranty with the cost to repair/replace the air shocks ($1200 per shock out of warranty at todays prices), rebuild or replace a tranny or many other issues. Not to mention the common rail diesel injection system. I love the torque for pulling my boat, the milage of the diesel over the gasser and the cost of the diesel GL is less than the GL 450. I do use the GL for my daily driver and on the weekends for most family outings. It is just a great overall comfortable ride. It is a pleasure to drive. So I agree with Steve that not everyone is having problems, you just have to decide overall is the GL right for you, considering all things. If you are going to keep it for any length of time, the extended warranty is a must.
https://mbworld.org/forums/diesel-fo...tec-motor.html
Post#10
https://mbworld.org/forums/4512302-post10.html
In 2007 it's my opinion Mercedes was still working bugs out of the system. The 7G transmission mated to a diesel was\is a tail kicker for them to program the shift software. Make sure you have the fluid changed with the newer spec fluid.
The Airmatic rear shocks must have come from a supplier that dropped the ball that day. Changed mine at 30000 miles or so due to leaks, and it's been fine ever since.
As for the tailgate, search the forum. That system had a flaw that would kill the battery because it did not close properly, and I think has a fix.
Overall not a bad ride, as thousands were sold as compared to complaints.
As for the oil, it gets dirty within minutes after changing oil. That the nature of an EGR diesel motor. Have the oil level issue checked. There was a faulty sensor fix (recall?) for that.
Oh, when I visited the factory, the rep told me that every part of the vehicle comes from US suppliers except the engine. (That's Deutsch) Part of the deal they have with the State for building the factory there.
Can't advise much on the sale/keep decision. In my mindset, MB's usually last a long time, even longer for diesels.
Do you even know what "rebuildable" means?
This information is 100% baloney in the fact that ZERO car engines are "rebuildable" given the criteria suggested.
The OM642 is a high performance AUTO engine, it's not some overweight slug truck engine. Somebody just gets his kicks badmouthing Mercedes and lots of naive folks just get on board.
Post#10
The current V6's are not sleeved, they have an aluminum block. When the time comes, they are scrap metal. When you turbo charge an engine (either gas or diesel) you add excess wear. You are getting more out of the engine than it is capable of in its naturally aspirated form. Effectively the turbo shortens the life. As I said before, I do not plan to drive anything for 500,000 miles. I will trade to update, upgrade etc before driving something that long. However there are those that will drive one forever. I just don't think you can afford to drive a MB that long. The repair costs would outweigh just buying a newer vehicle with warranty.
If you are implying that the engine is an aluminum block with coated Nikasil cylinder bores like a Jag or BMW you are dead wrong. It has cast-in-place iron liners, I have seen a cutaway display engine myself.
Second, this engine does not exist in naturally aspirated form, it has been built from the ground-up as a turbo diesel engine. the presence of a turbocharger does not imply any reduced life. In a diesel application, two of the biggest killers on gas engines do not exist on diesels. There is no throttle valve to cause turbine stall/cavitation and it is impossible to ping a diesel to death as you can a gas engine, because all ignitions in the cylinder are by definition, detonations. Being built from the ground-up means the engine is meant to work with the characteristics of a turbo, and as a result, unlike say a '67 Corvair, there is no risk of reduced life.
To the OP. You may want to check with your dealer. Mine is offering me $10,000 cash to bring my truck in early and get a new one. It seems they can't get enough diesels to meet demand in Canada, so they want every one they can get their hands on. Just check the prices in the Auto Trader!
This is a problem how?
You do understand, of course, that a nikasil/galnickel cylinder is WAY tougher than an iron cylinder.
Hey, if you don't want/can't afford a Mercedes, you don't need to manufacture excuses not to own one. Just don't.
Dude I have owned 7 Mercedes. If you read my post I stated I will not own one until the wheels fall off and I have to rebuild it. I said I trade to keep in warranty so I don't have to spend a ton on repairs, replacements, etc. It's all a personal decision. Do what you like.
Cheers.
I base this on what it cost me to build a race motor for my race car. And I didn't really go hog-wild with it, as the rules I run under don't allow that. Simple 1st overbore, balanced and blueprinted rotating assembly, simple cleanup head job (no porting/polishing), etc. EXPENSIVE.
- Mark
http://www.ourexcellentadventures.co...ents/OM642.pdf
...top of second page. I would not have bought it if it was. You just have to pick up any Canadian used car magazine to find people basically giving away 8-10 year old Jags that are burning oil. I don't think the the fuel is all that clean here, I know it is/was loaded with MTBE, and there is huge temperature swings. Somehow this does not seem to agree with Nikasil lining.
Now, as far as rebuilding goes, I see no reason that the iron liners could not be refinished or bored and sleeved like other engines of similar construction, but I have not seen any directive one way or the other from MB.
