Glass on roof peeling?
Old Apr 5, 2016 | 06:44 PM
clvincent's Avatar
e320
a few weeks after i got my GL i noticed looking from the inside the pano roof had small cracks in it everywhere
took it to my detail guy and he washed and waxed it and it looks fine
the truck spends probably 4-5 days full a week under a shade which is certain to make a big difference in arizona
it is my back up car and does not get driven as much
do think this car was probably garage kept its whole life in georgia before i got it, which probably helped too
but so far having it out here 6 months or so no issues
i usually take both cars in for a detail with wax every 3 -4 months , hoping this will prevent any issues with my roof
we will see, i will keep this up to date
Old Apr 5, 2016 | 07:05 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
I am also conjecturing that atmospheric contamination is part of the problem.
I purposely do not park outdoors at the airport.
Mine was a TX car for the first 5 years, but believe it was mostly garaged.
I looked at (and passed up) a FL car that supposedly spent a lot of time at the airport, and it was very bad.
Old Apr 5, 2016 | 07:27 PM
clvincent's Avatar
e320
i looked at 3 others before buying this one, all southeastern US cars and the other 3 pano roofs all looked horrible
but i dont know if maybe they had been waxed and cleaned up that it would have made a difference...
Old Mar 14, 2017 | 01:52 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
how about some pics?
Old Mar 14, 2017 | 03:52 PM
johny75's Avatar
'08 GL320
Originally Posted by N_Jay
Polish it like a headlamp and reapply a UV protectant Clear Coat.
Yes this approach works, I tested it. Start with 600 grit, then 800, 1000, 1200, 1500 wet sanding it and it will look like new. I tested one small spot on the back and it looked smooth and clear. However, it is a lot of work, so I decided not to do the entire roof , so now I have a small polished spot at the back : ) I don't care no one glares through it anyway. Only helicopters can see it .. lol . I have used the same approach on the headlights and I finished them, but they are small surface compared to the entire roof.
Old Mar 14, 2017 | 05:02 PM
N_Jay's Avatar
Don't forget the UV protectant.
Old Aug 7, 2017 | 08:14 PM
  #32
Jason B's Avatar
So in conclusion, no one has fixed this themselves yet.
Old Aug 7, 2017 | 10:18 PM
  #33
angelglo's Avatar
Veteran: Marine Corps
s500 GL450 GL63 Z71XL Yukon 67 396 SS velle 68 Vert Camaro 69 RSSS Vert Camaro 75 Blazer
I looked down at my 2007 GL450 from my bedroom and noticed that my back roof glass was very bad as well. my wife comes over and asks what I was looking at. I tell her that I was thinking about sanding mine down with a polisher and increasingly fine sand paper. She then says, no one can see it. She then ask if it affects the driving and I say no. She then tells me that I have better things to do like clean the house or drive the kids around.
I guess I wont be detailing my roof glass.
Old Aug 8, 2017 | 10:00 AM
  #34
N_Jay's Avatar
Tell her one of the neighbors mentioned it.
Then you get to buy that new dual action orbital polisher!
Old Aug 8, 2017 | 10:45 AM
  #35
mrmotoguzzi00's Avatar
going down to 600 is a little over the top, start at 1500 wet, aka put a hose on soaker and just let it flow over the spot your sanding, use a rubber sanding block that is flexible enough to conform to the curve of the plastic. I'd say for every sq ft or so of surface you may want to change the sand paper... if you don't you just sand longer for the same effect as using new paper Your Choice...
With a little practice you will feel the rough surface coming off aka it gets easier to sand, move to the next spot
At this point you can graduate to increasingly smoother sand paper and go over it again... 2000 then 2500, then 3000 or spend a bit of time with that buffer and cutting compound... go to an autobody paint supply store for the sand paper don't use home depot/lowes
with the 3000 it should look a satin paint job when your done...
time to buff it out...
don't skimp on the compound amount....
then go to polish with the buffer....
then wax....
Should be very shiny at this point
Mike
Old Aug 8, 2017 | 11:01 AM
  #36
N_Jay's Avatar
Originally Posted by mrmotoguzzi00
. . . then wax....
Mike
Are you selling or keeping?
If selling wax is "OK", but if you are keeping you need to have the surface sprayed with a UV protectant clear coat compatible with the acrylic material.
You can go 1/2 way by using a DIY UV protectant spray, but will need to clean, lightly polish and reapply every year or so.
