GL450 X164 few upgrades with Part Numbers
Old 05-13-2017, 08:15 PM
  #176
wally AMG's Avatar
MB
OMG ... old thread good memories...
Old 02-05-2018, 04:47 PM
  #177
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Guess what ???
Illuminated Star is on !! who said it is impossible ? Took me 30 min to install...
Yes, diameter is the same, fit perfectly, but you need to make about 3 small cuts to the grille to make it fit perfectly, I use a dremell, star look like is a factory accessory, about the wiring I will do it next week.
I heard it is impossible install illuminated star on a X164 because star is made for a X166, so star size is different, fitting is different, angled in different... bla bla bla...
Can you just tap into parking light wire? Got one and it has 1 red wire and one black. tested on 12v battery and lights up.
Old 02-05-2018, 08:02 PM
  #178
mrathell's Avatar
2009 GL450 SOLD / 2011 GL550 SOLD / 2013 GL450 current daily
So is there any reason why these illuminated grille stars wont fit on the 2007 - 2012 GL450's?
https://www.ebay.com/itm/Illuminated....c100290.m3507
Old 02-14-2018, 02:30 AM
  #179
wally AMG's Avatar
MB
Not sure about that one but for nothing I will install a fake chinese illuminated star....
Old 04-24-2018, 01:17 PM
  #180
Jason B's Avatar
Installing today.
Old 09-25-2018, 12:45 AM
  #181
PopoySD's Avatar
GL550
Is the emblem the same size from the x164 GL450 and GL550? I've been tinkering about the idea of installing the illuminated emblem and stumbled on this thread. There's a lot of less expensive ones nowadays on Amazon and eBay. So basically anything that fits a GL class X166 should fit with a little modification on our x164 GL550?
Old 09-25-2018, 04:31 AM
  #182
mbogohse's Avatar
GL 450 CDI
Thumbs up
Yes it will fit with a little adjustment, you may have to cut the casing to squeeze it in, but it will fit nicely. You might want to put some silicon to seal it thru. I did mine a while ago and I don't know if later production of the star were made any brighter, it only needs to be a bit brighter. Its easy to remove the original star, when unscrewing use a padded cloth so as not to mark the star.
Old 09-26-2018, 06:20 PM
  #183
PopoySD's Avatar
GL550
I don't think it does..it probably fits the GL350 and 450 but the 550's star looks bigger ☹️
Old 09-27-2018, 04:19 AM
  #184
Jason B's Avatar
I got from my supplier and I’m in this business and the one I got fits.
2010 impreza 0 60
Old 09-28-2018, 11:58 AM
  #185
PopoySD's Avatar
GL550
It's not the same size for a GL350/450 as a GL550, but if you can show me one that fits the x164 GL550, lemme know coz I've been looking everywhere
Old 09-28-2018, 12:00 PM
  #186
Jason B's Avatar
These are not listed to fit any x164 but the one I have did with a little dremel trim which cannot be seen.
Old 09-29-2018, 12:48 AM
  #187
PopoySD's Avatar
GL550
Yeah but you have a GL350... I think the GL550 is a different size. I may be wrong because I'm new with this too, but I've been doing a lot of research and comparing pictures. The x164 GL550 has a 9" star and I think the other GL's have a 7" star, which is why the newer emblems fit because it's still the same size. I posted some pictures from my prebprev post for reference
Old 10-02-2018, 07:20 PM
  #188
tmurphy25's Avatar
gl550
Hi, I had to add a little more velcro, but your absolutely correct they are a lifesaver. My friend left a 5lb bag of ice in the bag, and it melted... all fluid caught in the tray... disaster averted....
Old 01-12-2019, 01:54 PM
  #189
DrMel's Avatar
2010 GL 450
I have an illuminated star ready for install: https://www.ebay.com/itm/Illuminated...z/142844013814
It's 12v. Do I need to add anything or could I tap into the park light wire? What did others do?
And, what's the best way to remove the old star emblem from the grille?
Old 01-12-2019, 09:59 PM
  #190
BlownV8's Avatar
Received 1,073 Likes on 860 Posts
E55, GLS450, GL63, GLE350
That's what I would do.
Old 01-18-2019, 01:18 AM
  #191
Mikchek's Avatar
2001 S500 (W220) / 2007 GL450 (X164)
Originally Posted by KrustyKustom
Did you check StarTEK info? Pay the 19 bucks and do a search, probably on drivers side.
whats StarTEK?
Old 01-18-2019, 01:21 AM
  #192
Mikchek's Avatar
I would love to know the same thing...this should fit a 2007 GL450 right?
Old 05-08-2023, 12:05 PM
  #193
ltpace610's Avatar
2012 GL450
Hi Wally AMG,
I came across this old post of your about replacing the grill star emblem on your 2012 GL450. Your post has been the only one I've been able to find where this was successfully completed. As a matter of fact I haven't been able to find a post on how to remove the darn thing. My question is did you replace it with a star that was fitted for a 2013 GL450 (X166) if so was it OEM or aftermarket?
Thanks in advance
Old 05-23-2023, 05:03 PM
  #194
ltpace610's Avatar
2012 GL450
Hi,
Here is a link to a post I made.
I was able to find and install a star in my 2012 GL450
https://mbworld.org/forums/gl-class-...m-install.html
Old 08-13-2023, 08:18 PM
  #195
Zipher's Avatar
GL450
Found on Amazon $69
Found on Amazon. GL450 2010 is 18.5 diameter -
Amazon Amazon
Originally Posted by ltpace610
Hi Wally AMG,
Thanks in advance
Old 08-15-2023, 12:18 PM
  #196
Elbeau's Avatar
Mercedes gl450
This one.. I think twice, in my opinion, looks clean I like it ! I try it first... no regret, you can be the judge too..
Chrome Door handle Cup
PN B66-8812-37
I was thinking about those and I thought they may be too much. But they look pretty subtle in your close-up. How do they look from further away?
Old 08-15-2023, 12:21 PM
  #197
Elbeau's Avatar
Mercedes gl450
After
Guard Plate PN 164-884-01-90
That definitely looks better. My 2011 came with that. I thought it was standard.
Old 08-15-2023, 12:40 PM
  #198
Zipher's Avatar
GL450
I tapped into the fog lights on my 2010. If I want
It on I turn on fog light. I purchased a splitter connector
Old 08-15-2023, 12:58 PM
  #199
Elbeau's Avatar
Mercedes gl450
Also you can go with weathertech + MB floor mats... don't look to bad, any sugestion?
The Weathertech definitely look like a better fit/quality. The thing about all these protectors is they hide what you are trying to protect. And, in my view, they turn the luxury look into a utility look. So, I think putting the carpeted floor mats over the protective mats helps and, of course, they can easily be taken out when driving in bad weather or where they are likely to get dirty. That said, I do have a pet cover on my second row seats and cargo area. But floor mats can more readily be replaced if they get too dirty or damaged to clean.
Old 08-15-2023, 01:18 PM
  #200
Elbeau's Avatar
Mercedes gl450
It is alot of concern about GL550 wheels on a GL450, difference is GL550 have a fender flares also offset of wheels are a little dfferent (+/- 7), after replace the GL450 wheels for a GL550 this is the result... I don't think I need a feder flares..
I agree. I think the flares are more for appearance purposes - more aggressive and call attention to wider stance of the tires. But I think it looks better without the flares.
Quick Reply: GL450 X164 few upgrades with Part Numbers
