So started my build & scored some Mandrus Wheels
Old 03-01-2013, 03:45 AM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
found a set of used Mandrus stuttgart. Let just say i got it under $1k for the set of 4. 22x10.5 & 22 x9.5
Now parts list started to pyle up.
TPMS 433mhz sensors $175
black Carbon MB Center cap $30
Chrome Conical Lug Bolts 20pc spline type $75 (they are basically 20pc of wheel locks)
Tires Nexen 305/40/22 $550
Mounting $80
Akebono brake front Pads $80 (just keep brake dust to almost zero)
Alignment $80 (keep tire wear minimal)
So Estimated. total for the wheels and tires will be. just about $2000.
Oh also got a set of LED Taillight for $375.
Old 03-01-2013, 04:13 AM
fkong777's Avatar
I changed my plans from getting some 22" Mercellino AMG Reps
I did couple of fairly accurate photoshop using a members photo of a Silver GL. hope you dont mind.
Old 03-01-2013, 11:22 AM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
nice cant wait to see pics......do all GL s take a 433mhz TPMS does it have to be genuine....is there any programming .....
Old 03-01-2013, 12:17 PM
alx
alx's Avatar
Staggered wheels - you need to be careful not to end up with different diameter tires. This rewuirment might limit your wheel/ tire combo choices.
Tire diameter should be the same on all four.
Old 03-06-2013, 04:57 PM
fkong777's Avatar
Im not absolutely sure but I looked in http://epc.startekinfo.com
got this current part no for my vin. a0025408017 which was 433mhz.
I think when it all install I have to reactivate tire pressure monitor via the dash and steering wheel button in one of the menu in the information display.
Old 03-06-2013, 08:55 PM
KrustyKustom's Avatar
2021 V167
EPC
Off Topic...what browser are you guys using for EPCnet and startek info?
It worked on my windows pc a couple of months ago but no dice now, cannot figure it out.
Old 03-06-2013, 09:16 PM
fkong777's Avatar
IE9 or 10 with the latest JAVA installed works. I think some of the web site component didnt work a couple weeks back.
Old 03-20-2013, 12:27 PM
baldmike73's Avatar
'14 E63s Estate, '21 RR P525, '22 GMC 2500, '23 G63
with those wheels it makes the GL look more X5'ish -
Old 03-22-2013, 12:17 PM
fkong777's Avatar
Just got the wheels on. Here is a quick pic until I get some shots with better lighting.
Old 04-10-2013, 04:50 AM
fkong777's Avatar
More pics.
offset shot.
Old 04-10-2013, 08:38 AM
UDWANIT2's Avatar
nice looks mint.....sits nice with the body..
Old 04-10-2013, 03:54 PM
fkong777's Avatar
Thanks. These are basically S Class wheels. 22x9 +37, 22x10.5 +41
Old 04-10-2013, 04:07 PM
BlownV8's Avatar
Received 1,069 Likes on 857 Posts
E55, GLS450, GL63, GLE350
Looks nice. Those Mandrus wheels must be carved from the core of a neutron star. You just about need to upgrade the brakes to stop the wheels from turning.
Old 04-15-2013, 01:49 PM
fkong777's Avatar
Yes they are pretty heavy.. The center and front lip is extremely heavy. However the rear lip is really light.
I had to paint the rotor and calipers because they are so visible now. The OEM metal finish is extremely ugly.
Old 04-23-2013, 07:16 PM
s_lara@yahoo.co's Avatar
2010 gl450 x-164
Fkong777' nice ride. I am looking at the 22" replicas for myself. What was the ET, with and tire size were u planning on installing? We're they staggered? Any info will help. Thanks
Old 05-07-2013, 05:59 PM
fkong777's Avatar
My Mandrus are 22x9 +37, 22x10.5 +41 basically if you get the 22" S class staggered sizing it would look similar to my setup. I ran 305/40/22 tires on all 4 corners.
the AMG replica's specs are 22x9 +35 and 22x10.5 +35
Old 06-17-2013, 01:56 AM
fkong777's Avatar
Wheels update.
Old 06-18-2013, 06:18 PM
vntgspd's Avatar
Porsche 911
Do you have a pic from the front or back angle showing how much they poke?
Old 06-21-2013, 01:11 PM
fkong777's Avatar
not the best pictures but just here is a couple
Old 06-21-2013, 02:01 PM
2010 gl450 x-164
Did you lower it? It looks lower than the norm. If you did lower it, what are you using? Lowering module?
Thanks.
Old 06-21-2013, 03:21 PM
fkong777's Avatar
not lowered. The bigger wheels probably gives it a lowered illusion.
Old 08-14-2013, 12:44 PM
jperez3460's Avatar
2011 gl450
Did you order these for the S550? I checked the Marcellino site and the only offer staggered fitment for the sedan.
Old 02-22-2014, 03:04 PM
fkong777's Avatar
Yes they are S550 spec wheels. Since they are staggered. 22x9.5 and 22x10.5 Most wheels listed for the GL is the same width front and back.
Old 02-24-2014, 08:36 PM
UDWANIT2's Avatar
they recommend same wheels for 4matic staggered screws up the gears/plates on the 4 matic ….if u had your rears all around will look better cause of the deep concave…. i like that AMG style a lot it came 19in factory for my CLS ..
Old 02-26-2014, 04:58 PM
kingbolom's Avatar
GL450 / GSX-R / Acura RL / Acura TL Type-S
Nice looking ride man!!!
Quick Reply: So started my build & scored some Mandrus Wheels
