Steering wheel gearshift buttons
Inner - to restrict the shift range for the manual gearshift program : to downshift
Outer - to extend the shift range for the manual gearshift program : to upshift
My buttons only have one movement not two, is this an error in the manual?
My 07 has 2 black shifter buttons. Left one is downshift and if pressed, activates the manual mode of the vehicle. Right one is upshift and if pressed all the way until you get past 6th gear, gets you out of manual mode and back into automatic mode.
your GL only has "one movement"? Are you saying you can only downshift or upshift on 1 button only? Not sure if I'm getting you.
Yeah. If you could take of your steering column with the back of the steering wheel, it would more helpful I assume.
Your manual looks pretty normal to me.
Edit: Hmm that's a little strange. I'm looking at your image again and there's apparently 2 ways to push one of the buttons... Well I'm headed somewhere very briefly so I'll be right back.
I'll report if I can test that successfully or not.
Not sure if I have ever heard of that before. That's my brief report.
-George
-George
In it the UK
