GL320 Intermittent No Start - Battery Tests OK
Old Feb 11, 2014 | 07:05 PM
WC320CDI's Avatar
2008 GL320 CDI
Hi. I've got an '08 GL320 that I just replaced the battery with the proper Bosch unit and replaced the aux park battery. A couple times a week the car will not start it engage the starter once but not have enough juice to crank the motor. If I put the battery charger on the battery for as little as 5 minutes it cranks fine and will go the rest of the day ok. I had the battery load tested and it tests fine. I checked the voltage at the battery when running and it was in the 14V+ range indicating that the alternator is working right?
Has anyone seen this or have any ideas?
Old Feb 11, 2014 | 07:23 PM
alx's Avatar
alx
One or both of your battery terminals is dirty/ loose.
Old Feb 11, 2014 | 07:29 PM
WC320CDI's Avatar
2008 GL320 CDI
Good idea. I'll hit them with a wire brush but they are definitely tight. Why would adding the battery charger to the equation improve the condition if the terminals were dirty? Just adding more voltage?
Old Feb 12, 2014 | 10:41 AM
WC320CDI's Avatar
2008 GL320 CDI
Additional Symptoms Discovered
Terminals are all cleaned and tight. My wife has discovered that if she does not wait for the glow plug light to shut off and just cranks it straight over it starts. It is when she waits for the glow plug light to shut off that it doesn't start. Temperature wise it is in the garage that stays around 35F.
Any thoughts?
Old Feb 12, 2014 | 12:16 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Something does not add up.
The glow plugs come on when you try to start, the light coming on when you turn to run and not start is just the bulb test.
The car controls when and how long it cranks.
Old Feb 14, 2014 | 02:07 AM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
What is the CCA of the Bosh battery you installed?
Old Feb 14, 2014 | 09:07 AM
WC320CDI's Avatar
2008 GL320 CDI
The battery is 850 CCA, which is what PepBoys recommended.
As far as the sequence for turning the key, when I turn it to the first detent all of the dash lights come on and the glow plug light stays illuminated for a few seconds then goes off, all of the other lights stay illuminated. When I then turn to the next detent then the car cranks to start or in this case often just gives one click.
It has been observed if I just quickly go from off to start without pausing at the first detent for the few seconds for the glow plug light to go out it cranks and fires up.
Thanks for everyone's suggestions and input
Old Feb 14, 2014 | 09:11 AM
N_Jay's Avatar
The cranking is controlled by the ECU with input from the Glow Plug controller (and maybe other modules).
Is it 100% consistent with the fast turn vs. slow turn of the key? (or could you have built a superstition based on a few random occurrences?)
Really sounds like a bad starter, or starter solenoid/relay, except for the slow turn fast turn part.
Old Feb 14, 2014 | 09:17 AM
WC320CDI's Avatar
2008 GL320 CDI
I'm unsure of the 100% consistency of starting it quickly; my wife will be trying that start method all of the time to confirm or dispel that.
Do you know how to test the starter or solenoid? I don't have any shop manuals on the car so it likely is time I invest in one.
Old Feb 14, 2014 | 09:26 AM
N_Jay's Avatar
intermittent Starters are usually diagnosed by replacement (unfortunately).
I know so many people who have spent a whole lot of time replacing and checking everything else, finally to replace the starter and have the problem resolved.
Back when starters were $50 and easy to change, no one would give it a second though to do as the first or second thing.
Now that they are a few hundred and more difficult, people will spend many time more effort to avoid changing them.
Old Feb 14, 2014 | 09:33 AM
gmphertford's Avatar
S Class
Carry out battery drain test, did the non start issue also happen before battery replaced
Old Feb 14, 2014 | 09:43 AM
WC320CDI's Avatar
2008 GL320 CDI
No it didn't.
We got the car in July and around Dec the white battery light came on. Not being a member of the forum yet or doing any research I pulled the main battery out and took it to be tested where of course in hindsight PepBoys said it had a bad cell and needed to be replaced. Needless to say a few days later the white battery light comes on and then I do my homework to find out it is the aux park battery which is the culprit.
Thats been replaced now and at least a month went by with the new main battery in before this odd starting behaviour started. I suspected a bad new battery but it tests fine. Just doing a quick search on "remanned" starters I can get one for about $200 from my parts store so if they'll take it back if that isn't the problem I'll try replacing that first.
That or ditch the car as it has the dreaded oil cooler leak which I am very reluctant to invest 2k to fix.
Old Feb 14, 2014 | 09:48 AM
S Class
If you are having trouble with battery power u will need to carry out a battery drain test, to make sure there is no controls units still on and using power. Do you get ignition lights when trying to start vehicle
Old Feb 14, 2014 | 09:52 AM
WC320CDI's Avatar
2008 GL320 CDI
The car has full electrical power when it won't start. The radio works, the seats even have enough power to operate and all of the other stuff works. I have not checked the battery voltage yet at the moment that it won't start, that is on the list also. For the last couple of days it was been starting ok. When it happens again I'll check the voltage and tap the starter solenoid with a screw driver to see if that helps to diagnose it.
Old Feb 14, 2014 | 09:54 AM
S Class
They have problems with the ignition switch on them if you turn the key and the lights dont come on then needs new switch, everything on car will still work because you dont need ignition on for them to work
Old Feb 14, 2014 | 09:55 AM
S Class
lights on the instrument cluster
Old Feb 14, 2014 | 09:58 AM
alx's Avatar
alx
you can have enough amps to run all of the above, but not enough power to crank the high compression diesel engine.
if you cleaned your terminals - i think you are done.
next time you get that problem- replace battery.
Old Feb 14, 2014 | 10:37 AM
N_Jay's Avatar
When you try to start and it clicks does everythuing dim like the starter is pulling juice, or not.
If the starter is not pulling juice, it has to be starter or solenoid/relay.
If starter is pulling everything down then it could be battery and connections. (Hots and/or grounds)
Where are you and how many miles are on you GL?
Not to be too off topic, but how bad is the oil leak?
Old Feb 14, 2014 | 11:37 AM
WC320CDI's Avatar
2008 GL320 CDI
When it "clicks" it does not appear to be pulling any juice. None of the dash lights dim and the starter does not engage something just gives a single "click" but it isn't with enough force to be the starter bendix engaging the flywheel.
As for the car it has 62k on it and the oil leak is noticeable to the point there are a few drops on the floor every night. Over the course of 2k miles maybe a 1/4 of a quart has been consumed/leaked out.
Old Oct 10, 2015 | 02:00 PM
hmillham's Avatar
2008 GL 320 CDI
Was this issue ever resolved?
I am currently suffering the same issues. I've replaced fuel pump, battery and camshaft piston sensor.
If you were able to resolve it, what was your fix?
Old Oct 11, 2015 | 12:23 PM
N_Jay's Avatar
What is (or was; before and after each fix) your exact symptoms?
Old Nov 17, 2015 | 07:20 PM
Steven Miller's Avatar
2009 GL 320 and 1998 E320
So this was my problem
Fried positive cable ends melting the separator...hoping this finally solves this problem...many hours of labor, hope this helps someone. Have your mechanics check the positive cable all the way under front passenger carpet (forward of the battery about 2-3 feet)
Old Nov 17, 2015 | 10:11 PM
clvincent's Avatar
e320
Thanks steven for letting us know about that, sure it will save someone a lot of trouble in the future
Old Nov 18, 2015 | 07:19 AM
hmillham's Avatar
2008 GL 320 CDI
Thank you Steve Miller
I will most defiantly have my mechanic check this out, its got to be cheaper then new turbo and/or transmission based on the two different dealerships that have evaluated these same symptoms. I will keep everyone up to date.
Old Nov 18, 2015 | 02:14 PM
clvincent's Avatar
e320
millham, really hope yours is just the cables etc
will be much cheaper!
please do post back with what solves the problem and what else gets ruled out etc
