Rear hatch rerlease handle fix/replace
Old Aug 25, 2014 | 12:21 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Is there a way to lube a sticking real hatch handle instead of replacing it?
Anyone have a good write-up or video on replacing the handle.
Mine is sticking on almost every use now.
Old Aug 25, 2014 | 09:51 PM
N_Jay's Avatar
So, in looking around it seems the MKL, GL and R share this piece.
I found a video on the replacement on an ML and the GL looks the same.
I figured this piece was a combination electrical and mechanical release, but Noooooooo . . . . . .
It is nothing but a friggin switch that could have been a simple push button!
So has anyone taken one apart to figure out what binds?
Given the part is $50 used and $85 new, how hard is it to take apart and clean up and relube?
Old Aug 30, 2014 | 01:59 PM
N_Jay's Avatar
All fixed with a $15 eBay part.
Took about 45 min, but would have been a lot faster if I was not being extra careful about the clips and if I had known you needed to take the inner hatch handle trim piece off first.
Old Sep 2, 2014 | 10:05 AM
dagentooboy's Avatar
2008 GL320
What part? Mine was bad when I bought it and the dealer replaced the whole latch for free (it would have cost somewhere in the neighborhood of $730). Do you have any pictures/suggestions for next time?
Old Sep 2, 2014 | 10:15 AM
N_Jay's Avatar
There are two parts that seem to have high failure rates.
One is the latch, the other is the handle/switch.
They are independent. Mine problem was with the handle.
EDIT:
Here is a really bad price on a used part (more than new)
http://www.ebay.com/itm/09-MERCEDES-W164-ML550-Lift-Gate-Handle-Flap-Closing-System-Spare-OEM-/191260205919?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c87ff235f&vxp=mtr
P.S. I love these "Dealer" repair prices. Even at $100 for the handle and $250 for the latch, they are somehow adding almost $400 for less than an hour of work.
Oh, wait, I forget. If they did both pieces they had to take the door apart TWICE, because there is no labor saving when you do the receipt.
Old Sep 2, 2014 | 10:28 AM
2008 GL320
So.... could you still open it with the key or from the drivers door?
Old Sep 2, 2014 | 11:17 AM
N_Jay's Avatar
yep.
Opened fine, would not close if the handle stuck in the open position.
Just a little PITA
The handle is nothing but an electrical switch.
Old Sep 9, 2014 | 09:16 AM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
The best fix is to replace the latch. Lubing or spraying with WD40 is only temporary and will not do anything long term
Old Sep 9, 2014 | 09:34 AM
N_Jay's Avatar
Are you talking about the handle or the latch?
P.S. WD-40 is always a temporary fix. It leaves little to no lubrication after it evaporates.
Old Jul 26, 2021 | 04:46 PM
Biwinski's Avatar
Clk320 gl450
do you have the switch part number? I’m looking but can’t find the part number. You are talking about the outside handle that sticks correct?
Old Jul 27, 2021 | 09:49 PM
N_Jay's Avatar
I don't think the switch is available separate.
My switch was fine It was the handle that was sticking.
I got one off eBay for not too much, Then took minor part cleaned it and looked it and kept it as a spare.
Now my wife's E has the same problem so I need to find one of those handles.
