Brake Rotors
As I was browsing RockAuto.com and noticed that there are 2 different sizes of rotors... 373mm vs 350mm. I called my dealer and found the part number for front brake rotor of my GL350 is 1644211412... can someone tell me if this is 373 or 350? Also, should I go with oem rotors or after market rotors?
Are you doing all the brakes or just front?
Generally you can get 2 sets of pads between rotor changes.
Seems front pads run about 50K and backs about 100K but depends on driving style.
It is a personal choice.
Fronts I tend to be a bit pickier as to how good they have to look to keep them.
P.S. Not arguing with a MOD, just showing there are a range of opinions on the topic.
P.P.S. I have never seen the value in resurfacing, unless you REALY can't afford new rotors, the old rotors NEED it, and you can get it done WELL and CHEAP.
FCPeuro website says the rotor needs to be replaced if there is a lip. I almost placed an order on new rotors.
STANDARD practice with these vehicles is replacement of pads and rotors at same time, every time. New pads for these vehicles are quite thick and their life is essentially that of the rotor — 2mm wear. It’s forbidden to put used pads against a new rotor, and if you do just replace pads, it’s guaranteed the rotor will reach its wear limit before those new pads are worn out. That is a waste of money, then.
resurfacing Mercedes rotors is never authorized by Mercedes and it’s in fact ridiculous to think it would be.
just understand … experience with ‘merikun iron is 100% irrelevant to Mercedes.
they had a lot of extra metal to shave off and could usually be cut two or more times.
All carS have upped the precision of their engineering and efficient design. So there is much less wasted material and less margin.
given that rotors have generally gotten less expensive, and labor has gotten more expensive, so it hardly ever is worth cutting them.
There are those who think MB has a warehouse of pixies from which magic dust is extracted to sprinkle into various components like brake rotors.
I believe what has changed is expansion of product liability. MB is safest just telling people they have to change the rotors. MB is thus shielded from liability due to people improperly machining rotors, and bonus gets to sell more rotors.
I don't think it is liability, or we would see it on all cars, but more about maintenance philosophy.
MB seems to work on the premise that their owners want to bring the car in once a year and never more.
All service seems to start with thinking that car should be as close to new as practical and remain so for the following year of service.
When you bring it in, if there is a chance the brake pads won't last a year, you end up buying new pads.
If there is a chance the rotors won't last the pads, you also get new rotors.
