Check engine light next day after oil change...car jerks sometimes and just stalled
Old May 17, 2016 | 11:52 AM
mrdavidalexande's Avatar
2007 Mercedes GL450
I had an oil change the other day. The check engine light came on when driving on highway but no symptoms. Then the next day it jerked when going up a hill a tiny bit. I called the shop and they can't look at it right away. But my wife now tells me it stalled on her in an intersection. Any idea what this might be? It seemed to idle high for a minute the other day too.
Old May 17, 2016 | 12:38 PM
Bimmer777's Avatar
2010 GL550, 2013 C63
May be unrelated to oil change. But in any case, anything will be a guessing game on what the problem is before the codes are known. Sounds like its misfiring, which would be caused by either coils or spark plugs. At least I would check those first. I wouldnt drive it before you figure out what the codes are.
Old May 17, 2016 | 05:05 PM
alx's Avatar
alx
Given the info you provided nobody here can provide you with an answer. The car needs to be read. Oil changes generally don't have the described by you effect on vehicles.
Old May 17, 2016 | 07:31 PM
islandbeef's Avatar
2012 GL450, 2013 Lexus GS350 F-Sport
+1
Get the codes. The car will tell you what's wrong. Hope things work out!
Old May 17, 2016 | 11:48 PM
GodobeMB's Avatar
2007 GL450
Oil change could have contaminated fuel/emission line, and clogged catalytic converter. If its the cat it would definitely trigger the CEL.
