Lights On Most Of The Time - Cant Turn Off From Switch
Old Feb 20, 2017 | 08:09 AM
carlosamg50's Avatar
AMG GLS63
Hi all
Late 2011 GL500, even on the sunniest of days the lights come on so I have the dipped beam, DRL's in the front bumper cover and the small yellow colour sidelights on as if I am driving at night. I have the switch set to 0 and it does it most of the time, occasionally the dipped beam doesnt come on so I just have nice white DRL's but then the lights trigger thinking its dark and the DRL's dim a bit.
Ive tried the switch position in Auto, 0 and all other options but nothing can actually turn the dipped beam off when its on.
The lights work fine when I turn the engine off and lock the vehicle up, but I seem to have no control over them when Im driving, do I have a bad switch, if so how do I remove and replace or can I reset the sensor or something?
Carl
Old Feb 20, 2017 | 11:04 AM
alx's Avatar
alx
sensor needs to be checked with star/ das. it might also need to be reset.
they do go bad. rarely, but there is a history of it.
Old Feb 20, 2017 | 11:30 AM
AMG GLS63
Is the reset with STAR / DAS only or can I pull the fuse to reset it?
Old Mar 14, 2017 | 03:55 PM
007_e350's Avatar
X166 gls450 2017
Originally Posted by carlosamg50
Hi all
Carl
Go through your instrument cluster lighting settings and turn OFF Daytime Running Lights - you can only do this while engine is off
You will however lose the illuminated LED bar upfront when sun is out, it will come on when headlights are turned on
Old Mar 15, 2017 | 08:41 AM
WaveyKat's Avatar
Something Slow
Nope the GL550/GL450 2011 and Below sucks when it comes to the light sensor.. on cloudy days my headlights doesn't come and works like it should, on but on a sunny bright day headlight light are on like its dark out.. its a weird system and most people have this issues nothing to worry about or REST.. I tired I have a STAR/DAS system.
Old Mar 15, 2017 | 08:45 AM
AMG GLS63
Yes mines weird like that too, I can start her up and the dipped beam is off so I only have nice white DRL's in my bumper cover then I drive up the road on a sunny day and bang, lights come on, my DRL's dim down and the front now looks very old and out of date.
Ive since found that putting the switch to the day time driving position only will bring on just the awful yellow side lights which is even worse.
Had a 166 ML63 prior to this GL500 so you can imagine how I hate the yellow lights in this 164
Old Mar 15, 2017 | 11:51 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
So I'm lucky that I have a 2012? I guess those don't have that issue, even though the 2011 looks pretty much identical to the 2012. Maybe Mercedes updated the sensor?
Old Mar 15, 2017 | 04:06 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Never had that issue on my 2007.
Old Mar 20, 2017 | 10:34 AM
WaveyKat's Avatar
Something Slow
yes I think they did updated the Sensor from 2012+ and 07 doesn't have LED DRL :-)
From looking at the EPC seems that the Light Sensor have been Replacement with a New Part Number Two times By MB..
so they probably new there was issues.. idk
new part number is A1648203085
Old Mar 20, 2017 | 11:07 AM
Jason B's Avatar
Has the sensor, which is on the dash in the middle. A smoked looking lens, change in shape in anyway for the new part? Might be an easy way to tell who has what if it does.
Old Mar 20, 2017 | 11:45 AM
007_e350's Avatar
X166 gls450 2017
how do we put it in
Is it the one on windshield ?
Old Mar 20, 2017 | 01:01 PM
Jason B's Avatar
Maybe have some other owners post their's? Maybe it physically looks different for those offending years,.
Old Mar 21, 2017 | 08:19 AM
WaveyKat's Avatar
Something Slow
I have the 2011 GL550 And from looking at the EPC the Rain/Light Sensor is mounted right below the rearview mirror on the windshield ..
The Yellow Circle is the Sun-Sensor A2518203810
as per this thread
https://mbworld.org/forums/e-class-w...nsor-what.html
Old Mar 21, 2017 | 12:37 PM
Jason B's Avatar
Hmm, that thread says for E class... SO you're saying in a 2012 GL that yellow circle isn't for lights?
Old Mar 21, 2017 | 02:25 PM
WaveyKat's Avatar
Something Slow
nope, from the EPC it says that's the Sun-Sensor which has to do with the HAVC
Old Mar 23, 2017 | 01:55 PM
Jason B's Avatar
Ok, can we get an actual photo of the sensor on the windshield?
