got 20 inch wheel but label says 19
i would run the following psi on all four corners on trucks that are regularly driven with 4 or less people on board:
18" - 30-32 psi
19" - 32 psi
20" - 34 psi
would not run anything larger that 20" on those trucks as front suspension as far as i am concerned is weak- especially the steering rack...
so.. in my experience the values above provide the best compromise of tire wear, handling and comfort. on 18" and 19" i would run even closer to 30 psi, but the wheel pressure sensors are hard coded to show low pressure condition at 30-ish so your dash will lit up.
It varies by tire, both by maker, by design, and by size. The Ecstas, final weird problem notwithstanding, seemed to want even higher pressures. I was running 38 front 43 rear. One-size-fits-all pressures simply don't work.
Get a caliper - and monitor your tire wear as it depends on pressure.
It's better to err on the side of too much pressure than too little. Tires underinflated wear faster than overinflated by the same amount.
