A/C compressor jump
So, how do I jump the low pressure switch to get the compressor to run to pull the freon out my can to recharge?
I arrived at the need for freon based on typical symptoms of low refrigerant: a/c compressor clutch does not engage, intermittent cooling.
Also, its the easiest and cheapest solution. Makes sense to start with the cheapest first, right?
The compressor on those cars uses a refrigerant control valve to vary compressor displacement and thereby the amount of work it does. If that valve is failed (usually the problem), it will not cool most of the time, even though there's plenty of freon.
Why don't you have someone check the vehicle who actually understands how it works, before you just dump refrigerant in there.
FWIW, if the system is empty, the pressure difference from the full can to the empty system will allow enough to flow in to kick on the compressor if it's just waiting for the pressure to come up. It has to drop very low to disable toe compressor. However, if it's disabled and there are faults, it may not run until they are cleared. Needs proper diag to find the source of the not cooling issue.
Can't find any DIY videos online. I found a couple threads here and the other forum that said it was fairly straightforward. I am open to any tips you guys might have.
It really isn't that bad at all. I started a new thread with the parts I bought and general how-to-replace steps since I couldn't find one anywhere online. https://mbworld.org/forums/gl-class-...ement-diy.html
p.s. Go Juventus!
What Italianjoe said. I didn't change it since it likely wasn't the problem in my case. At $30, maybe I should have. So sorry, can't be of much help as I did not look into how to replace it. Good idea with the manual download. Please do let us know how you do it.
Yeah, at 100, you definitely have to get that fixed soon. My wife's 7 months pregnant and 85 here (Louisiana) felt like 100 to her, haha.
