Leak at oil filter
Any suggestions before trying a new cap?
thank you.
I originally had a leak around the ccv cap. I had that changed a few weeks ago. Then soon after changed the oil. So I have been nothing more oil on the engine. Defiantly a spray as it is on the foam under the engine cover.
I also noticed spray spray around this area behind the oil fill cap. I am not sure what it is for It is yje plastic piece with the two hoses crimped to it. You can see the oil collecting on the intake underneath
Dan
EDIT: Oh, if you're pretty sure you know where it it coming from, then maybe just clean that area real well. Or secure a rag around the area as you may be able to tell if the rag is getting soaked from the inside or the outside. Just some other thoughts!
That is the fuel line return hose, it has nothing to do with oil. There is an o-ring under that fitting on the top of the fuel injector that will sometimes fail and leak diesel. To remove the fitting, you pull the circular plastic part up (pry very gently with a screwdriver) then lift it off.
Anyone have issues with the pump leaking?
again an 08 gl cdi.
thankypu
I am hoping that it's not caused from excessive blow by. I would not think as it really does not burn much oil. I don't have to add between 7500 mile changes
on a positive note did pass 150k last week
will report back if not.
