07 GL450 Suspension Malfunction
07 GL450 w/ 210k miles.Every part of the Airmatic has been changed out at least once during it's life. Arnott air shocks in all four corners.
Driver front suspension dropped to bumpstops. Psgr front looks similar but not as low. This has repeated itself not three times, with the last time being after we changed out the driver level sensor since the Autel Diagnostic was showing error 5130 ("check component B22/8 Left Front Level Sensor"). Switching this part for new didn't fix the problem. Rear does not drop. When the front drops, dashboard error of Suspension Malfunction displays and the vehicle will not respond to any suspension commands via dashboard. Clear out error codes on the Autel and the compressor kicks on, raises vehicle and it functions normally, until the problem resurfaces.
1st time suspension dropped - parked overnight in garage
2nd time - +7 days later, parked overnight in garage
3rd time - +4 days later parked overnight in garage
4th time - level sensor replaced, +4 days later, vehicles parked in garage, looked ok at 8am. Came back at 11am and suspension was dropped.
Since the air comp. does turn back on when the error code is cleared, we don't think that's the issue. Since left level sensor was replaced and issue repeated, don't think that's the issue. Thinking it may be a slow leak in the driver side airbag. Just not sure why it's so intermittent.
Any thoughts, ideas, directions to look at appreciated.
Thanks.
Shop cleared the error codes and the compressor turned on and raised the vehicle to normal ride height. Shop also removed the new level sensor and reinstalled the original level sensor, since this didn't fix the issue. Parked in garage and I raised it to offload height. Measured ride height on front driver side, since that's where it drops. Visually and physical inspected air shock and performed soap test (no access to the backside of shock) but nothing seemed out of ordinary.
+1 day: measured ride height again and verified it hasn't changed. Visually, the other three corners look unchanged as well.
Looking at my records, I replaced the left and right air strut as a warranty replacement from Arnott at 166k miles two years ago. Around the same time & mileage, air compressor and pressure valve were also replaced. Current mileage is 209,800.
Since the issue still occurred after replacing the driver side level sensor, i don't suspect that.
Valve block was replaced about 50k miles ago.
I guess it could be a leaking air shock, but wouldn't this be evident by now? Ever since I parked it, the height hasn't changed one bit, checking it regularly with a tape measure. I"m wondering if the suspension somehow "locks" in place at offroad height, not relying on the air shocks to maintain level? Doesn't sound like it should, but if it's a leaking air shock I would suspect to see some ride height sagging at this stage.
Could a faulty air compressor and/or relay be the cause, intermittently causing a "suspension malfunction" error through voltage spikes/drops even when not in use? But then this should be evident with some sort of error code related to the compressor, right?
Ideas and thoughts appreciated. Thanks.
I'm replacing the strut later this week and will update thread.
Now that it's parked, I've left it at regular ride height and noted the height for all four corners. I'm going to monitor over the next few days and see what happens.
I'll update it the issue persists.
i haven’t driven the car yet as I need to replace spark plugs and get t9 fixing the intak manifold lever arm, hopefully by simply popping it back in the socket and not having to remove the entire manifold.
Ill update id the replaced air shock doesn’t fix the issue.
Working on manifold issue to get it past smog test...
