Headlamp upgrade advice and experience
After much online research, I see 3 upgrade options:
1. Upgrade halogen bulbs to something like . Most simple to do (just changing a bulb) but results are only moderately improved over OEM.
2. Upgrade to HID. Several kits available (for example ). But it seems like a difficult install (
3. Upgrade to LED. For example . In terms of Lumens, these are definitely the brightest option. No need for external ballast. Not a lot of info online (maybe because it is relatively new technology?). Some people complain the light pattern is inferior to HID. The lamp base is large so I don't know if it will fit in the housing without modification. Also the clips will likely need to be modified.
Looking for any advice and experience--especially plug-and-play upgrade kits with new clips or professional install. I am looking for lights that will provide the most visibility.
Thanks,
Dan
Our 2016 GLI has oem xenons....and even my ML 55 from 2000 came oem equipped with Xenons...
Shame! dingaling aling :P
Go for a xenon retrofit! It should work perfectly in the stock projector bulb housing and xenons will apparently provide better light quality than leds....
I have done a lot of research including talking to some installers and most everyone agrees that HID is better (brighter). Apparently the Lumens rating for LEDs is misleading. Also, some people claim that the LEDs do not work well with a projector lamp. So, I have two more questions:
1. For HID you need to choose between 35w and 55w. Is there any reason _not_ to get 55w?
2. Any recommendations for a specific conversion kit? Most (almost all) are under $60 . But some, such as http://www.mteclightingusa.com/MTEC_Xenon_HID_Conversion_Kit_Mercedes_Benz_X164_p/hid-x164.htm are $260. Is there any reason to pay the $200 premium?
BTW, in terms of installers in the SF Bay Area, I have found:
Xtreme HID
T&R Lighting
Bright Auto Lights
Thanks!
Dan
If interested, we offer a specialized Morimoto/Hylux blended kit which we’ve found to work best with MB G/M line power specs. Retails $150/kit.
It's important to understand that the technology is maturing. Not the individual parts, but how the manufacturers are putting them together. In just the last few years they've gone from a bunch of stuff randomly slapped together to settling on a respectable, robust design.
Anyway, I'm pretty happy with mine, and no way would I put $$ into a trailing technology like HID. Before long there won't be a non LED bulb on a car.
As for the other point.... the issue with LEDs isn't LEDs as a technology or even performance.... it's the light spread pattern in housing not designed specifically to capture LED surface mounted light spread. You often end up with reduced throw distance, dark spots, and light scatter. HIDs are true 360 spread similar to halogens, and the halogen housing is better designed to capture and project forward that full lighting spread (although admittedly at a slight variance in focal point).
I'm not out to harsh your biz or sell LEDs; just saying what I found.
For what it's worth, looked into lighting for off-road purposes. That's like 100% LED now.
1. Upgrade halogen bulbs to something like Philips X-treme Vision. Most simple to do (just changing a bulb) but results are only moderately improved over OEM.
2. Upgrade to HID. Several kits available (for example Kensun HID Xenon H7 Conversion Kit). But it seems like a difficult install (YouTube video). Bulb retainer clips need to be modified. Ballasts need to be installed, etc. I don't think I want to attempt it myself but would consider with a professional install. Online comments seem to favor mostly this option.
3. Upgrade to LED. For example HIKARI LED Headlight Bulbs Conversion Kit -H7. In terms of Lumens, these are definitely the brightest option. No need for external ballast. Not a lot of info online (maybe because it is relatively new technology?). Some people complain the light pattern is inferior to HID. The lamp base is large so I don't know if it will fit in the housing without modification. Also the clips will likely need to be modified.
Thanks,
Dan
Xeonx Depot has excellent costumer service and they warrany all thier products. The extreme kit is the best by far if you're looking for a bright white color.
I recently swapped my 2010 GL550 factory Xeonx bulbs for real Phillps Xtreme bulbs. They'r 100% genuine as they came in a box with numbers you can check through Phillps website.
My only problem is I came to MB from Lexus and even with the Xeonx bulbs, I need more light on the road.
Has anyone installed small discrete LED fog lghts?
I was referencing the OP.
My situation is I have a 550 with the lighting package. The factory HID system does NOT put out light enough for me on the road. I have the small LED strip where some have the factory fog lamps.
I was curious if anyone has added LED fog lamps that have an actual LED projector? The current LED strip are DRLs. I suppose I could swap to factory fog lamps but I would get the bright white color I'm trying to achieve.
I've searched and was unable to locate any threads regarding the issue.
Its getting up there in age so perhaps switching out the xenon bulbs may be do the trick.
This may get you the light output you want: http://www.xenondepot.com/D1S-philip...85415xv2c1.htm
Any one know how to properly change out the stock HID bulbs though? Don't want to fry myself...
Sorry Yup! Didn't realize you had mentioned it above!
http://www.aznoptics.com/index.php?m...products_id=74
Good luck!
do you also carry the Philips extreme vision d1s
bulbs?
Still having trouble finding directions to replace the bulbs
If you're reasonably mechanically inclined, it wasn't terribly difficult. Figuring out how to to get the bumper cover loose enough to get the headlights off the car was harder than the work on the headlights themselves. If heating up headlights in the oven to soften up the sealant holding the headlight together isn't your thing, companies like Lightwerkz (and others) do retrofits as well as sell parts. HIDplanet.com is a great source of general information as well, but there isn't much there on GL/ML retrofits unfortunately.
Quick question, would you be able to post a picture of the beam patteron on the headlights on a wall or something to easily see the cut off? Thanks again.
Also, how long did the retrofit take? My GL550 is my daily driver. Lastly, I infact do have Philips Xtreme now. What K degree are your lights? I believe mine are rated at 4700k. They are pure white, but like you said it didn't make more light on the road.
Hey yup,
Would this work for you? 6 inch seems to be the right size for the stock led and this is surely brighter and road legal too.
https://www.lightwerkz.net/index.php...s12-white.html
The White Visions are either rated as 5000 or 6000k depending on where you look. I'd guess 5000 is closer to accurate. They are a nice white light without any blue tinge to it. If you want more blue, the brand new Osram CBBs look to have almost as many lumens as the White Visions, but have a cooler look to them.
It took me about 6 hours from start to finish, but I was taking my time to make sure everything was done correctly. I probably spent 4 on the first one and 2 on the second. Getting the bumper cover off was the hardest part. What wasn't obvious is that there is a U-shaped piece of metal that clamps the bumper cover to the front of the fender that has to be slid off for the cover to come free. Another tip is that the wiring to control the shutter on the bi-xenon projector (the one with the blue connector) can be disconnected from the stock projector and and will plug into the EVOX-R so no wiring hackery is needed. Lightwerkz was very helpful and got the parts to me in 2 days from NJ to CA on an order that got to them late in the afternoon. Fantastic service overall.
GL550 Bi-xenon
EVOX-R projector output on road
EVOX-R projector output on wall
HID's still perform best in the stock GL headlights. I've seen both led and hid. Hid has been perfected in this case for this truck since it was designed around his from the factory.
