GL320 2008 Diesel cranks but won't start when the engine is hot
Old Dec 21, 2017 | 07:06 AM
memaf's Avatar
GL320 2008 Diesel v3.0
Question GL320 2008 Diesel cranks but won't start when the engine is hot
Hi everyone,
I'm very new in this forum. Anyway, i have GL320 2008 model Diesel which cranks but won't start when the engine is hot. I tried changing CPS but didn't help.
Now a different mechanic is telling me i need to replace 4 injectors. But i would like to be sure if there is a possibility that a bad injector(s) can cause this problem of engine cranks without starting when hot.
Thank you in advance for any insight that you may provide.
Thanks,
Old Dec 22, 2017 | 01:29 PM
johny75's Avatar
'08 GL320
If you have a bad injector, I would think there would be code on the dash pointing to it, or some other code related to misfire, rough idle, etc.. If you don't have any dash lights, then I myself doubt this is it.
Old Dec 22, 2017 | 09:42 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Dispersion values
Originally Posted by memaf
Hi everyone,
Thanks,
Nothing in your post indicates where you are located (USA/elsewhere?) so we have no idea if you are close to a dealer. But if you are, you can have a diagnostic run on your engine to measure the dispersion [correction/deviation] values of the injectors. If the injectors are the cause of the problem that test will show it. If all the injectors are within limits it is hard to see how the failure to hot start is related to them.
The cost of the dealer's diagnostic time is cheap compared to the cost of replacing 4 injectors if that isn't necessary.
Old Dec 26, 2017 | 09:22 AM
memaf's Avatar
Thank you johny75 and Fourdiesel for your suggestions/ideas. I'm also doubting if injectors are the cause of this. It only occurs when the engine is hot. After the car has started the drive is very smooth, no misfire at all. I will take it to the dealer for a second opinion.
Cheers,
