GL500 does not crank starter
Old Mar 16, 2018 | 02:32 PM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
Hi guys, I have a 2007 GL500 that had the a worn voltage regulator and had toasted the ECU on May of last year. Well, since then I have replaced it, bought a used ECU that was sent for reprograming and then I found the ISM was also bad. Well I have replaced the bad ISM for a new one yesterday. I programmed the ISM using the Star Diagnosis and everything was fine, except that the car has a error number 2912 reported by Star Diagnosis. It is supposed to be a failure in N47-5 (ESP) module that is not sending the proper response by CAN bus.
Well, my doubt:
Why the car does not crank the starter?
The battery is fine, it has 12.6 12.8V
The starter is fine, I have just tested it pulling out the starter relay and made a direct connection.
All the lights on the dashboard are coming on without any alert, anda I can also insert the key and turn it to positions 1, 2 and 3, but I can't start the car.
I am looking for suggestions.
Thank you,
Sergio
Old Mar 16, 2018 | 08:35 PM
machadosl's Avatar
Well after I have replaced the ISM there are no issues.
Today I found that the engine start is not released by the ECU, I tried to release but I had no success as Star Diagnosis kept for more than 10 minutes analyzing the module without any response.
Thank you.
Old Sep 2, 2018 | 06:00 PM
machadosl's Avatar
Just making an update of my first post.
Unfortunately the computer I use for diagnostics (Dell D630) has a issue with its processor so, when I try to release ECU engine start it freezes.
I bough a new computer of the same brand and model to make a swap with the hard disk fro the old one to the new one, but, I did not know that Star Diagnosis program only works on the computer it was installed, this is terrible!
Now I have ordered a new Hard Disk with Star Diagnosis from 2017 from China, let's see if it works when arrives.
