Random Misfire, Smoke, gas smell and Ambient Air Temperature Problem
i am leaning towards faulty ecu harness.
i would start by taking truck to dealership and paying for one hour to verify all grounds and harness fusable links. if those check out i would verify all connectors around the ecu and visually inspect all harness lengths i can get my eyes on
Now, that doesn't mean that your other errors are secondary. I'm just saying, tackle first things first. Overhaul those connectors. Get yourself three wash bottles. Fill the first with DI ("distilled") water. Vinegar and a baking soda solution (doesn't have to be strong; like a teaspoon per quart) in the other two. Flush them out with vinegar, then baking soda, then rinse with DI water. Blow them out with compressed air, then reconnect. You don't have to use much of any of the three liquids. Possibly leave the vinegar sitting in the connector for a few minutes.
The corrosion may have gotten deeper in, like into the crimps between the wires and the spades and lugs. But, again, first things first.
The connector to the temp sensor is down low, near the front, right? Exposed to the road salt?
In my experience the limp mode results in the ECU vomiting up an assortment of other codes. The rough idle and stuff sounds like limp mode, in which the fuel system goes open loop. That is, it stops using feedback from the exhaust to adjust the air/fuel mixture. It runs the motor lean to protect the cats.. Your MBII will tell you whether it has gone open loop, but not explicitly. You have to look at the S1 oxy sensor output. I forget which direction the lambda goes, but I think it's values greater than 1, with 1 being the target. When it goes open loop, other motor diagnostic stuff pops up, which the system figures it's better to not ignore and reports anyway.
Yes the outside Ambient Temp is right at the front on front bumper exposed to road derbies.
One thing I am having problems here in Brazil is with the poor quality of the fuel, it gets old faster leading to these misfire problems in my car. I am going to replace the spark plugs that are on it for lazer iridium to see if this can solve my problem.
If there's fouling in the injectors or head or combustion chamber, you need to run a PEA (or related) additive to dissolve the deposits. Changing the spark plugs won't do much.
I don't think the issue is with air/fuel ratio. The motor might make more power with proper tuning; possibly the alcohol contributes too much oxygen, so the ECU runs the motor lean ... that sounds like what your plugs are telling you. It shouldn't be a big effect, though.
Proper tuning wouldn't stop the real problem due to the atmospheric moisture being drawn into the fuel by the alcohol. I assume your air is humid; you don't live in the high plains of western Brazil, do you? If you have to store the vehicle, top it up with gas and put in a gasoline stabilizer.
You could run the fuel through a molecular sieve ... but frankly you'd be more likely to die in a fire than save your engine.
Thank you!
Finally weather got a lot better and can work outside on the car again.
Yesterday I found a connector not plugged on the front bumper right by the washer fluid. cleaned the ambient sensor, connector, and newly fount connector and plug them. Now the temperature is displaying correct outside temp. Check engine light has not come back on yet. Vehicle seems to be running fine so far (approx. 10 minutes drive) will get back with more update, no misfire, codes or stalling yet. I am not thinking that the problem has been solved yet.
I am planning to check every electric connection now since I found one just laying there.
Will keep you guys posted.
