Engine swap
I was very skeptical but that’s awesomeWas thinking could have install a widband o2 sensor just to confirm air/fuel correct. Plx has some good units and ways to monitor. If off could probably then get a custom tune.
it is a 278928 30 1717137.
The S550 and CL550 appear to have the same engine. I have heard anecdotally that the sedan engines will fit, with swapping the oil pan. This appears to be consistent with your experience.
Do you think i am on the right track? Any other advice or preventative maintenance that should be done while the engine is out? Rear main seal for example?
swap the upper and lower oil pans from the GL's original engine,
Use the GL engine harness and ECU,
Swap over the rear heater coolant wiget that connects to the back of the engine(if its a different style than the GL's)
Its actually one of the more plug and play swaps I have preformed. Do the above and you should be good to go. For my swap I had a 2007 GL450, I purchased a 08 SL550 engine off ebay. Price wise, not the cheapest strategy but my entry cost on the GL was on the ground.
Few ongoing issues to sort drivability yet, intermittent fuel pump function(I believe the fuel pump relay socket contacts are loose), the air suspension is getting completely replaced(when I got the car the suspension was completly empty, linkages are siezed and its stuck all the way up right now), small coolant leak on the radiator neck, overall engine bay clean up/reassembly.
Any xentry with dev mode has a disclaimer in German as part of the startup - „dieser program“ (Oder was) “Ist mit developer mode ausstattet.”
you will need dev mode to do the coding I am speaking of. It’s not available under drivetrain -> ME (motor electronics) 9.7.
i also don’t know if it will have any effect as you are literally the first use case.
