Winch
Old Feb 16, 2019 | 08:39 AM
eric_in_sd's Avatar
2007 GL450
Well, consider that the grille impedes airflow, but no one seems worried about that. Air goes around things. I'd say if you can fit it in there without committing unnatural acts, you'll be fine.
Old Feb 16, 2019 | 09:22 AM
DennisG01's Avatar
'08 GL 320 CDI
I looked under my hood and I initially thought "What are these guys thinking? There's only a few inches of space in there." Then it dawned on me - I have a diesel so there's an intercooler in front of the radiator. But, without that intercooler, you guys still think there's room? And mounting it there would be strong enough? Mounted in the middle like that (away from the true structure of the car)?
Air does go around things. But airflow also changes at higher speeds. Just to be sure, it might not be a bad idea to make a mock-up and secure it with duct tape and zip ties - then drive around for a few weeks. 'Course, not being sure where you are Jake, it might be better to wait till the middle of Summer to test the true effects of it. Luan/hardboard would work well to create a rough mock-up.
Old Feb 16, 2019 | 04:43 PM
Jakehabing's Avatar
2008 gl450 x164
I live in the midwest, good idea on the mockup
Old Feb 16, 2019 | 05:17 PM
DennisG01's Avatar
'08 GL 320 CDI
This might be easier than luan... use that pinkish foamboard from Home Depot. Very inexpensive - And you could glue layers of it together, then do a quick shaping to mimick the winch.
Old Feb 17, 2019 | 10:48 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Following with great interest. I don't think that aluminum piece will withstand any pull force without buckling, though, which is what it's designed to do.
But when kitting your truck up for offroading come compromises to crash safety are just part of the process.
Old Feb 18, 2019 | 09:44 PM
Jayculbertson1's Avatar
Mercedes gl
Thumbs up 07 mercedes gl 450
this is what it looked like
I installed a winch on 07 gl 450, it wasn't a problem at all, however I think it did affect the adaptive cruise... I think that what it was?? but I didi. do it.
Old Feb 18, 2019 | 10:36 PM
  #32
Jakehabing's Avatar
2008 gl450 x164
Jay,
do you have more details on what you did to install the winch, like did you find a kit, or is it all custom work. Also how is it working out, you gl looks cool, mine does not have the adaptive cruise so i am not worried about that. One more thing, do you think it would be possible to install a hidden winch inside the bumper. Again cool looking ride.
Old Feb 18, 2019 | 10:47 PM
  #33
Mercedes gl
Custom job...just cut out two square holes in front to match up with the inside of frame, which the frame is in 3 sections in the gl, for safety reasons, so it will collapsed in accident, but just bolted the tubing to frame and the welded the winch mount on the tubing and mounted the winch to it. it works fine, I've had 3 of them so far, it worked on all them, I just bought my 4th one, which is a diesel, 11 model, so I'm anxious to get started on it next...Thanks
Old Feb 19, 2019 | 07:27 AM
  #34
Jakehabing's Avatar
2008 gl450 x164
That's really cool, I just knew there was someone out there that had done this. If it's not to much trouble, take some picture as you modify the 11, and post them. I know at least all of us following this thread would love to see exactly how your installing it.
what size of winch did you go with?
Old Mar 13, 2019 | 12:49 PM
  #35
Jakehabing's Avatar
2008 gl450 x164
Hidden winch
I think I have figured out how to install a winch behind the grill. Just waiting for tax return, and the fun mon before I try it. I will take pictures and post them for all others that might want to add one too.
Old Mar 13, 2019 | 12:52 PM
  #36
eric_in_sd's Avatar
2007 GL450
I think I speak for all when I say we are extremely interested in the outcome. Please do follow up.
Old Mar 13, 2019 | 01:16 PM
  #37
eric_in_sd's Avatar
2007 GL450
Many thanks from all of us for the pictures and info.
That's one bad to the bone benz.
Old Aug 13, 2019 | 10:00 AM
  #38
Bimmer777's Avatar
2010 GL550, 2013 C63
Bump this thread. Love more off-road/overland threads popping up lately and this one interests me quite a bit.
Did Jake figure out how to mount a hidden hitch? Any more info/pics from Jay and his 2011 diesel install?
Old Aug 14, 2019 | 08:37 PM
  #39
eric_in_sd's Avatar
2007 GL450
Someone needs to PM Jake, see if he's still out there and if he ever got his tax refund.
Old Oct 18, 2019 | 12:18 PM
  #40
not2fast's Avatar
In the market
WHICH WHEELS and TIRES DID YOU GO WITH?
Old Oct 18, 2019 | 03:23 PM
  #41
Jakehabing's Avatar
2008 gl450 x164
I am still out here, I did get my tax return, but family emergency came up. I think i have figure out how to do the hidden winch. Saving up because I want to install a warn. If any of you have the gl320 oil cooler will get in the way, with my idea, sorry. When I do it I will include picture. I did go with falken wildpeak at3 tires.
Old Oct 18, 2019 | 05:00 PM
  #42
DarthVaderpa's Avatar
X166 GL550
What size?
Old Oct 18, 2019 | 08:03 PM
  #43
Jakehabing's Avatar
2008 gl450 x164
265 60 r18, but they have other sizes too.
Old Dec 25, 2019 | 06:04 PM
  #44
Ilyak's Avatar
GL420CDI
Winch mounting
Did anyone ever do this? I’m selling my landcruiser 5.7 on which I mounted an excellent 13500lb winch hidden behind the front number plate and want something for my GL, for when I get stuck in mud, bought a portable 3000lb winch which hooks over rear towball and looking to fit a secure central mounting point I can at least hook it to easily if a hidden winch is too much, thinking of simply screwing a wide steel plate on top of aluminium with a fixing to attach winch to. Thoughts?
Originally Posted by eric_in_sd
Now I remember looking into this. It's a box section of aluminum. Depending on the winch strength, and how you reinforce how it attaches to the aluminum, and how you reinforce how the aluminum mounts to the bumper, I bet you could get away with mounting the winch directly to the aluminum.
Extruded aluminum is really tough. You'd be surprised.
Also, you can't just get rid of the aluminum; it is actually functional. I think.
Old Dec 25, 2019 | 06:09 PM
  #45
Ilyak's Avatar
GL420CDI
Hidden winch
did you do it? Interested.
Here’s hidden 13500lb dynema winch on my landcruiser stuck in mud with trailer using the GL as an anchor to pull itself out!
Old Dec 26, 2019 | 08:49 AM
  #46
Jakehabing's Avatar
2008 gl450 x164
Ilyak,
You are thinking exactly like me, only I would not drill the aluminum bumper. Instead I would mount the plate to it with 2 to 4 square u-bolts. This way we keep as much integrity of the bumper as possible. If you have a diesel this idea will not work. The oil cooler is right where the winch would be. Also a 3000lb winch will be too small, you need at least an 8000lb winch. Good luck.
Old Dec 26, 2019 | 10:45 AM
  #47
Ilyak's Avatar
GL420CDI
I took the front grill off briefly in a free moment of self-indulgence before picking up kids for Boxing Day pilgrimage to my mother(!) and there’s about 10-15 cm by 30cm+ in front of the inter cooler on my 420CDI (winch plate can sit over plastic/foam bumper slightly) which should fit a 4500lb winch which is all I really need. The landcruiser is a solid steel ladder frame built for a winch with big recovery points and I was happy to stick a serious 13500lb winch to use for all sorts of stuff like pulling trees but I fear pulling that much on the GL, however reinforced will change its shape forever and not in a good way!
I’m not going seriously off road and unless you get seriously stuck in deep mud or a ditch most people never ever need anything like full winch capacity. I have hilly land with clay which becomes a perfect lubricant when wet, I don’t sink in but I don’t move forward. If I get bogged down even fully laden with a 3.5T trailer on a 1 in 8 that’s still just ~800 kg to move it unassisted by the wheels and really all it wants is a good nudge to get tyres moving to bite on fresh ground.
4500lb is over 2T which is as much as I’d ever want to pull on that bar even reinforced and if I get really stuck I can use a ****** block back to towing eye and pull effectively 2T on winch and 2T on towing eye to get 4T total pull. If I’m really still stuck with that which is theoretically enough to lift the car with a ton trailer on the back vertically, I’ll call a mate rather than pull the front off by myself!
Plus a smaller winch is not only lighter but generally faster, you can get a ~4hp motor on a 4500lb winch but rarely much more than about ~6hp on a bigger winch as battery is limiting factor and bigger winches are geared down more to get the force so are often painfully slow to reel in unloaded.
It’s on a long list of projects to start (and even longer to finish!) but will take pictures when I try.
The 3000lb portable winch was mainly for moving trailers and stuff about, bloody handy and very cheap and no messing to install already found having it in back helped out, I paid about £50, it’s worth having a play and seeing what’s mere 3000lb on towball wrong way round can actually do.
happy Christmas and New Year!
Ilyak,
Old Dec 26, 2019 | 12:49 PM
  #48
DennisG01's Avatar
'08 GL 320 CDI
Ilyak, you mentioned using the front bumper tow hook (eyebolt). As I was reading through your original question, that was the exact thought I had, too. With a portable winch, using the factory tow hook seems like a perfect solution. Is there a reason you want to do something different? In other words, why "reinvent the wheel" if you don't need to?
