Timing Chain Options?
Old Mar 3, 2019 | 05:36 AM
zerochills's Avatar
GL350
Time for the timing chain replacement, 2011 GL350 w/ 124k mi. Has a pretty load chain slap for the first 2-3 seconds after start up. So, I have been reading up on the repair and began calling around to Indy shops and diesel performance shops in the area. Seems like estimates are coming in over a wide range ($1900-4300). I am assuming the lower end estimates are just pulling the valve cover and feeding the new chain in as opposed to the higher estimates which I assume is pulling the timing cover and replacing all the guides and using the one piece chain (already riveted)?
Am I correct in this assumption?
Any reason to stay away from a diesel performance shop vs. and Indy shop? I've read both good and bad about dealer timing chain repairs and seems like an Indy shop is the way to go (more experience)?
I've also thought about doing the job myself (yes, I've read Sak's very descriptive write up), weighing out the options and trying to make the right choice.
Thoughts???
Old Mar 3, 2019 | 10:55 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Do you really love your diesel and plan to keep for a long time? If not, trade in and cut your losses. It's ridiculous that you would be replacing a timing chain so early but I've seen a lot worse. The OM642 is fraught with issues and this is the first of many you will have with the vehicle.i
If I was going to keep, I would take it to a good independent that had extensive experience with this engine and would do it the right way and not just roll a new one in. The front of the engine will need to come off so the tensioners can be replaced. It's a big job to do it the right way.
Old Mar 9, 2019 | 11:09 AM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
http://www.stephensservice.com/bluet...ssuesproblems/
