has anybody had their tranny diagnosed?
Old Mar 28, 2019 | 06:18 AM
Mikchek's Avatar
2001 S500 (W220) / 2007 GL450 (X164)
Hello everybody I was wondering if anybody has had their transmission replaced, rebuilt, or at least diagnosed and is willing to show m a copy of the invoice.
i would greatly appreciate it & it would help me out a bunch!
thanks in advance!
Old Mar 28, 2019 | 02:49 PM
kcmgt's Avatar
08 GL320cdi, 08 ML320cdi, '10 ML350 Bluetec
This isn’t exactly what you are asking but until anyone else responds, see if this helps. I’ve got a 08 GL320 (130k) and the valve body is creating abnormal shifts. Harsh downshift into first when ambient outside temp is low and fluid not warmed up. Occasional slight upshift flair reminiscent of the old 123/126 body diesels. Theory is the bores inside the valve body have wear and pressures are not able to be maintained for some of the shifts. This one has had 3 tranny services so not necessarily neglected compared to some. I’ve gotten quotes for a new valve body and controller (also called a conductor plate). The conductor plate is what requires the coding (easily done at the dealer or Indy with the right programmer). $2100/$2200 parts, fluid, filter, labor and coding. I also got a quote for a factory reman transmission and it is $3850 (part only). This comes with a new valve body and controller ($1350 value +/-), filled with fluid and ready for install. I also got a quote on an independent rebuild and it was similarly priced at $3890. It either used my existing valve body/controller or additional cost for those parts new. Install costs on the factory reman obviously vary with dealer hourly labor rates and/or what an independent might charge you. The quotes I’ve gotten at dealers are within 5% either side of $5k for the reman installed (coded, out the door). The next hiccup (in the world of reman transmissions) is to do (or not) a torque converter. Most rebuilders don’t want to warrant a rebuild without including a rebuilt torque converter. The independent rebuild quote came with torque converter and the factory one is $1200 extra. Factory warranty is 24mo/24k miles and it includes the labor if done at a dealership. Hopefully this will help.
Old Mar 30, 2019 | 07:17 PM
eric_in_sd's Avatar
2007 GL450
Replaced with rebuilt, ~$5K installed.
Here's the rebuild shop I got it from https://mercedesdismantlers.com/722%209.htm According to thread on Benzworld, they do good work with the mods.
You need to see the invoice? I don't mind sharing, but let me know what you need from it.
Old Mar 31, 2019 | 12:00 PM
Mikchek's Avatar
i would greatly appreciate it if I could see the invoice. I have an aftermarket warranty & I would like to get an idea of what is involved so I don’t get any surprises before I spend any money!
Old Mar 31, 2019 | 12:01 PM
Mikchek's Avatar
thank you for you insight. Is the valve body & conductor plate considered a internal lubricated part?
Old Mar 31, 2019 | 02:51 PM
eric_in_sd's Avatar
2007 GL450
$4550 parts & materials
Note the trans includes a rebuilt torque converter.
Old Mar 31, 2019 | 03:39 PM
Mikchek's Avatar
Thank you bro...you are the best!!!
can you tell me or show me the labor to put it in?
Old Mar 31, 2019 | 08:23 PM
eric_in_sd's Avatar
2007 GL450
Sure thing. Hope it helps.
It's weirdly hard to see. Look in the left hand column. $785 install, $105 flush cooler.
Freaked me out, too. I thought maybe i'd gotten ripped for $890!
eric_in_sd's Avatar
2007 GL450
p.s. lol @ the string of fault codes as long as my arm
Old Mar 31, 2019 | 08:25 PM
eric_in_sd's Avatar
2007 GL450
Pretty sure they swim in the transmission fluid. That probably qualifies as an "internal lubricated part".
Old Apr 4, 2019 | 01:19 PM
Mikchek's Avatar
yes it is but the turbine sensor is an electric part which my warranty does not cover ugh!
Mikchek's Avatar
I was looking at that like dang
speaking of the fault codes does 2016-02-23 represent when you got the work done?
