2015 GL350 brake pads
you are posting in the wrong forum. You would want to re post this in x166 forum for more members to chime in. Here is a link to the write up I did on the front pads and rotors
https://mbworld.org/forums/gl-class-...y-picture.html
Can you jack up the car securely? Do you have a torque wrench for the lug bolts?
But... in no particular order, but the general idea is:
-- Disconnect the brake pad sensor if applicable.
-- Remove the caliper slide pins.
-- Firmly rock the caliper back and forth to squeeze the pistons and allow the caliper to slide off.
-- Secure the caliper.
-- Remove the pads.
-- Compress the pistons more - take the extra step of opening the bleeder while doing this, if you want. Don't let air in.
-- Clean things up.
-- Replace using good hi-temp brake grease on contact points.
