Front Lower Control Arm Bushing
Old Aug 5, 2019 | 05:12 AM
gl786's Avatar
GL320
Hey All,
Have gone through many YouTube and many google searches but can't find any proper guidance.
Has anyone replaced the bushings for the front control arm rather than replacing the whole control arm? If yes any tips or tricks.
I am just confused with the removal of this, refer to picture. Is it just like any other bush.
Old Aug 7, 2019 | 02:58 AM
maxusa's Avatar
2013 E63 P30, 2010 GL550
I have done it 2 ways: proper way and low-tech way. The proper way is to use a shop press. I have also done it by drilling out plastic/rubber, pulling the bush bracket with jaws, then cutting off the inner sleeve with a rotary tool. In either case, remember to mark the exact position (several degree rotation) relative to the casting line for the replacement bushing. Recommend a 20-ton shop press, which can be picked up for around $150 at Harbor Freight on periodic sale. Rent other tools for free at a local autoparts store. Hope this helps.
Old Aug 7, 2019 | 06:12 AM
gl786's Avatar
GL320
Thank you so much
Great to know it’s possible, time to order some parts
Old Aug 9, 2019 | 02:20 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Originally Posted by gl786
Hey All,
I did it once, the wrong way. Proper way is to remove the lower a-arm and press the bushing on - it requires a lot of constant, linear force to go on there.
The wrong way would be to feverishly dingleball hone the bushing until a large enough hammer can beat the whole assembly onto the a-arm that you didn't remove from the car while the hobby shop personnel are looking at their watches because they close in 15 minutes.
Old Aug 11, 2019 | 05:22 PM
pavulon's Avatar
BMW M5, Subie outback, Cruze td, GL550, LPE 630 C6 Z06
For the time and money, it would seem reasonable to just take it to a machine shop and have them remove the worn bushing and install the new one. Take some time to give them some clear direction and it should be a low-time, straight forward thing for a place with the correct tools.
Old Aug 8, 2020 | 09:23 PM
jonathankreb's Avatar
'98 E320 and '08 GL320
I think I am on the horns of the same dilemma. I hear a rattling sound in the front suspension when I go over uneven pavement, and looking around/prying with a bar, the only conclusion I come to is that the rubber in the rear bushings on the lower control arms look to be cracking, and might be allowing a metal-on-metal contact. So I wonder, should I just replace the rear bushing, or since it sounds like the best practice is to remove the entire lower control arm anyway, maybe just replacing the entire assembly is the better course. I figure if one of the 3 bushings is shot, then the others are probably not far behind. Any thoughts from the community?
Old Aug 8, 2020 | 11:00 PM
chassis's Avatar
2017 GLE350 4MATIC
Rubber components don't last forever. It's a "while your in there, might as well do it" thing. If it were mine, and I had the tools or could get them, I would do it. Getting the tools includes having a local shop nearby that is capable of replacing the bushings.
Old Sep 15, 2022 | 10:18 PM
robbie59's Avatar
2013 GL550
X166 2013 GL550
I took apart the entire drivers side suspension components looking for the reason for the creaking and clunking. I found the lower control arm carrier bushing was loose and spinning on the arm. I don’t think it’s supposed to do that. I grabbed a new one from the dealer$$ and installed it in about an hour. So far no more annoying sounds and drives good as new. Hope this solved it.
See video
FullSizeRender.MOV
Old Sep 16, 2022 | 09:06 AM
eric_in_sd's Avatar
2007 GL450
Originally Posted by robbie59
X166 2013 GL550
MB has funny problems with the suspension. For example, the swaybar bushings are made to clamp to the bar and fasten to the frame, forcing the rubber bushing to absorb torsion when the swaybar flexes. After bushing installation is completed, the bolts clamping it to the bar should be removed, but this is not in WIS.
The effort involved in replacing the lower control arm bushings - why not just replace the entire lower control arm? They aren't that expensive.
Old Sep 16, 2022 | 04:32 PM
robbie59's Avatar
2013 GL550
I didn't think a new carrier bushing could be pressed on since mine was probably compromised. I bought a entire new control arm and it fixed my problem.
Old Sep 16, 2022 | 05:56 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
Good advice. I had mine pressed out and between the cost of the bushings, the hassle of dropping off/picking up the control arms off at a place with a press and the cost of the labor, I'd just replace the control arms if I were doing it again.
Old Sep 16, 2022 | 07:54 PM
eric_in_sd's Avatar
2007 GL450
Rock Auto has URO parts lower control arm for $125.
Take the old control arm to a recycling yard and get a nickle of that back.
Old Sep 16, 2022 | 07:57 PM
eric_in_sd's Avatar
2007 GL450
That's the other point - how do you determine the control arm is still good enough to take a new bushing, plus how would you know the guys that pressed it in did a proper job.
Was your point of the video that the bushing spinning freely indicated something had gone badly wrong? "Compromised"?
Like how when you really chowder a wheel bearing, the race starts spinning in the hole, ruining that suspension component?
Old Sep 17, 2022 | 03:29 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Lemforder parts are avilable at FCP Euro. I bought the set at had them installed. Lemforder are OE quality and you should be happy with them.
Old Sep 17, 2022 | 05:35 PM
EWT's Avatar
EWT
My admittedly limited experience with no-name chinese suspension stuff has not been good. I'd spend the extra for Lemforder. No issues with Lemforder upper control arms and Lemforder bushings on my lowers so far.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
