power liftgate using buttons opens but wont close/move
I understand that the tailgate opens but doesn't close using the buttons, so the motor appears to be functional. If you've managed to remove the button, then try using your trusty multi-meter to test the switch/button connections on the tailgate, and at the fuse(s).
Test for continuity and proper voltage. You might also try applying voltage directly at the button terminal to see if it engages the tailgate motor (just tap and listen, don't make prolonged contact (more than a couple of seconds) lest you burn out the motor) - this will tell you if there is a connection issue between the switch(es) and the motor.
Hope this helps a bit.
In addition, my 1 a clock pin on the 7 pin tow plug was not giving the 12v+ current, so I wonder if this is related. I ended up giving it power from the fuse box directly, so my brake controller works, but this just bypassed the problem, it did not solve it.
Example Tailgate Latch Lock Repair
