2010 Gl 450 beeping
Old Jan 8, 2020 | 09:09 PM
serb's Avatar
2017 GLS 450,Bmw Z4 35i
2010 Gl 450 beeping
Test drove 2010 gl 450 today and it beeped couple times without any obvious reason,is it almost dead battery or something else?
no warnings on the dash at all just random beeping
106k miles,dealer wants 12k plus all the fees
Old Jan 9, 2020 | 10:17 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Run don’t walk.
it may just need a new battery or it could be random power interruptions because of water flooding in the areas where the battery bus bars and sensitive electronics live. Electrical weirdery in these cars is rarely good.
Old Jan 10, 2020 | 02:24 PM
expl0rer's Avatar
GL550 X164
Originally Posted by Max Blast
Run don’t walk.
It may just need a new battery or it could be random power interruptions because of water flooding in the areas where the battery bus bars and sensitive electronics live. Electrical weirdery in these cars is rarely good.
Could it be Parktronic (there are no messages on the multifunction display that I am aware of) audibly complaining and 4 red lights on the front proximity monitor (on top of the dash, located in the center) illuminating? The beep is loud and lasts about 5 seconds, after which it stops and the Parktronic system shuts off in about 20 seconds (the button on the center console illuminates w/ a red light).
In my case, I have narrowed it down to an intermittent faulty front sensor with a visible dimple. The other sensors are dimple free. Only seems to happen in wet weather (for now).
Or it could be something else (and more expensive).
Old Jan 10, 2020 | 03:45 PM
DennisG01's Avatar
'08 GL 320 CDI
Obviously we're only guessing on this, but the Parktronic system sounds like the most logical thing. A quick scan with the proper scanner would probably tell what's happening. It could be a simple, inexpensive fix... could be more. Other than that, $12K sounds like a very good deal if it's up to snuff.
Old Jan 11, 2020 | 12:09 PM
serb's Avatar
https://www.audiwestmont.com/used/Me...b4fdc9f374.htm
very nice car,felt really solid and healthy.
salesman turned off the P button while we were driving but it kept beeping,in unlocked fine,started without a key,opened and closed tailgate no problem.
Old Jan 11, 2020 | 02:44 PM
serb's Avatar
Gl
Car sounded and felt really healthy,engine start button works without a key,tailgate opens and closes no prob,windows and sunroof open and close no problem.
Even if its a battery its no big deal,has new intake manifold and front struts and front tires what i could see in the carfax
Old Jan 12, 2020 | 12:05 PM
expl0rer's Avatar
GL550 X164
If it's not Parktronic, then I would ask the dealer to figure this out and tell you what is causing the beeping. If they don't or can't (w/ or w/o the help of an MB or independent shop which should be on their dime, IMHO), I would walk away. At 12K, I am not sure they would be willing to go through the trouble. This car looks like a pre-facelift, so are you sure it's a 2010? Or did the 450s get the facelift later? My 550 is 2010 and has the DRL LEDs. On this one the fogs/DRL are halogen. They are located on the front bumper.
Beeping in complex cars is a concern if they can't tell you what's causing this and you can confirm that it is true.
Old Jan 12, 2020 | 01:08 PM
mefferso's Avatar
BMW 335d
Mine would beep when the brake sensor made connection because the pads needed to be replaced.
Old Jan 12, 2020 | 02:39 PM
serb's Avatar
550 has a different grille than 450,yes this is a facelift
Old Jan 12, 2020 | 07:08 PM
Max Blast's Avatar
NGL450 w/EORP, S550
so it’s not Parktronic.
when a GL beeps it is usually accompanied by a message in the dash
if no accompanying message then there’s electrical gremlins afoot. Recommend having them or you take it to an MB dealer for a Prepurchase Inspection. They should be able to pull codes and tell you if there has been repeated instances of battery voltage dropping below 12v, which is what a water induced electrical problem often manifests itself like - random shut offs and beeps.
plenty of other non gremlinous GLs out there, why don’t you look at those?
Old Jan 12, 2020 | 07:13 PM
Max Blast's Avatar
NGL450 w/EORP, S550
mine just says “brake wear” with no beeps.
Old Jan 15, 2020 | 11:56 AM
espensen's Avatar
GL320CDI 2006
Turn the PTS off and see if it stops the beeping...
Old Jan 15, 2020 | 12:00 PM
DennisG01's Avatar
'08 GL 320 CDI
FYI...
Old Jan 15, 2020 | 12:24 PM
espensen's Avatar
GL320CDI 2006
Ahh, didn't see that
Old Jan 15, 2020 | 12:50 PM
DennisG01's Avatar
'08 GL 320 CDI
I miss lot's of thngs...
Old Jan 15, 2020 | 04:23 PM
serb's Avatar
Salesman called me and he said he is gonna take care of that beep,they have mb dealer next door within their company,lets see if he solves it,really like the car,the only thing it needs a good paint correction and ceramic coat to look perfect.
