GL 320 rear end sagging
Is there anyone in here who has experience with this problem and may be able to point out some "common" problem points that may be causing this?
Best reg
Tore
If you really wanted you could get some leak detector spray and find which bag is leaking...but why spend lots of Kroners and time on that.
15 minutes per side and you’re done.
If against all odds it still sags check the hose connections on the bags and then the valve block.
Yes, it's quick to change the air bags, I've done that before.
What is a little unusual is that both begin to leak at the same time.
Is it the case that if one is punctured, then it will affect the other?
In other words, are they connected to each other in the valve block, which is the next point that can fail?
Best reg
Tore
Best reg
Tore
I have several questions that maybe the community here can help me with. Lifted the car to the highest level and sprayed the bags behind with leak tests. No leak found on the bags behind. The car stood for about 12 hours without falling down. So to the questions.
Should the compressor start with only the ignition on without the engine running?
I started the engine and set the switch to the lowest level, the light in the switch flashed, and the instrument showed that it was about to lower, but nothing happened.
Put the car in gear and drove a few meters back and forth and then it began to lower to the lowest level.
Is that how it should be?
I will leave it in the lowest position to see if it falls from this position.
Where is the valve block and compressor located in the car?
Best regards
Tore
Now, just because the bags held air in the fully raised position does not remove them from suspicion. Also try to soap them up in the normal position. It is very possible that you have a pinhole leak in one of them that is exposed and allowed to leak when the car sits just so. it’s super frustrating to troubleshoot and this is why Arnotts free replacement policy comes in handy.
the valve block and compressor are in front of the passenger side front wheel and are accessed by turning the wheel full right and removing the front half of the wheel well liner.
***If you are breaking connections to the valve block your car must be on jackstands***
The workshop chain "Mekonomen" (they are a supplier of Arnott in Norway) finally approved to change my air bags. Expect them to be here in a week.
At the same time as I talked to my supplier in Norway, I sent an email to Arnott's Europe office and they may have had an impact on the decision of my supplier.
Happy ending so far
TT
Hey y’all. I have a similar issue as well with my 2011 GL450. It happens randomly but I will get a malfunction message that pops up while driving. Sometimes on highway or while driving at speeds around 30 mph. Also, the ride height seems a little low as well ( could be wrong. There’s 5 fingers of gap) but I doesn’t seem to effect driving at all. One side on the passenger rear seems a finger lower than the driver rear though. Could it be my sensors as well? She’s at 80k atm. Any info helps. Thanks! 🙏
