Been noticing the AC in the car has been getting less cool. Driver side warmer.
Connected the gauge just to see where things were. Followed the instructions, and noticed the gauge was showing it was at the top of the "full" (green) level. I thought that was strange. I didn't feel comfortable putting anything in to a pressurized system if it was full, so I didn't.
At the time of doing this, I didn't realize the driver side air was a different temperature than the passenger side, I only realized that tonight. I went through about 15 minutes of testing at various temperatures and determined the longer / harder the fan blew at lower temps the driver side simply lost it's coolness, while the passenger side still remained fairly cool. I don't know if it was at it's coldest level, since it was in the high 70s this evening where I live, but it was significantly colder than the driver side.
I called a local indy place that works on mercedes and they suggested for $250 they could check it out, determine if it's a temperature sensor issue, check the pressures, extract the frion, add new, and add a dye so that it can be checked at a later date in case the leak is small or large.
Before jumping on that, I want to make sure there isn't a simple test or check I can do myself that might be an easier / cheaper solution.
I had read in another forum but for a different make of mercedes about accessing the diagnosis panel via REST, etc.. but I couldn't find something similar with the x164. Following the same steps with this vehicle did not give me any kind of diagnosis panel.
Anyways, thoughts?
Anyways, thoughts?
https://itstillruns.com/reset-merced...m-7899592.html
Will try.
I've head it from 5 seconds up to 1 minute. Search google I can't seem to find anywhere where this test is used on ML or GL models...mostly C and E class mercedes.
Anyways, thoughts?
I had the same problem. I added a can with stop leak and dye in it. Its been 1.5 year and it has been working well so far.
Like I said, the needle (at the time) was at the TOP of the green section of the AC PRO can, therefor the idea of adding anything seemed like a really bad idea. The last 2 times I've checked, the needle has been at the 3/4 mark in the green..but even then, just randomly adding 134a when the gauge isn't even showing low seems reckless.
If you would like to shoot in dark, you can put some more freon in and see if it helps. If you have to pay later to get all freon out, it is worth a shot any way.
You can try use a ultraviolet light to check for leaks hoping that previous fill had UV dye in it if it was ever repaired.
I ordered a new compressor, got one off ebay. However, and this is important to note....there are 2 specific Denso compressor models that happen to show up as "matches" for GL450's when it comes to 2007-2012s...but AFAIK, only 1 model works for 2006-2008, and one works for 2009-2012.
This is the style (notice the bulkier front) my 2011 GL450 has: https://www.densoproducts.com/product.aspx?zpid=27710 Even the FITMENT tab says 2009-2012. This is #471-1436.
The version that pops up as well is this one: https://www.densoproducts.com/product.aspx?zpid=27765 (notice the front difference), this one is #471-1594. This is the one the ebay store sent me, despite showing a picture of the 1436 AND using 1436 in it's page description.
So I am not even going to attempt to install the 1594 one, who knows if it would even work properly.
