Rear Bumper Side Cover Part Number
So I had a little mishap this past weekend.......(dont ask...DOH). And I am trying to locate the part number for the rear bumper fender flair and I cannot seem to find it anywhere. I can find the rear quarter panel, I can find the front quarter panel, and I can even find the front bumper side cover, but not the one for the rear. UGH!!! Anyone know this part number? See picture below for passenger side rear bumper fender flare. Even the parts diagram doesnt show it.
Thanks in advance
Thanks in advance
Yup497 (10-18-2020)
Edit: this might be for the front fender, not the rear bumper... proceed with grain of salt
I just bumped (no pun intended) into those a couple of days ago. They are not listed intuitively, imho. I used a 2010 GL550 for vehicle filter. Other years might be different part numbers.
https://www.mymbgenuineparts.com/v-2...or-trim-fender
Wheel Flare
164-884-60-22Wheel Flare, Right
Outer, rear.
Wheel Flare
164-884-59-22Wheel Flare, Left
Outer, rear
Wheel Flare
Outer, rear.
Wheel Flare
Outer, rear
Wheel Flare
Outer, rear.
Wheel Flare
Outer, rear
Yes....these are for the front. It really crazy...I am able to find the front flare (both pieces) and the rear quarter panel flare, but not the bumper flare. I found a thread that shows the part numbers for all 4, but when I got to mercedesparts.com the part number provided doesnt even link to this flare......UGH....I may have to bite the bullet and contact the stealership.
As for the wheel.....was towing my boat and the lugs for the wheel spacer sheared off. Probably should have took the spacers off, as they werent designed for this load over long distance. Definitely an Uh-Oh moment.
Yes, Ill have to go to the dealer at this point, was just hoping to find it on line somewhere, but Ive got nothing concrete as of yet.
Go the dealership... buy something... a couple quarts of oil or whatever... then ask for the part number and just tell them you were going to look around online, but if you can't find it, what it could cost here?
What is the objection to calling the dealer? Other than price shock? You know the price will be high. So you won’t be surprised, right?
Call 6 dealers and compare prices. You will probably see large differences.
Do the homework on this. On the 4th dealer call you will have more information than them which puts you in a stronger position.
Also a solid data point to avoid use of spacers.
