Replacing my rear bags with Arnott, however one question/concern (towing)
Could those who tow and have used Arnott please chime in ASAP please and give me some advice. I need to order within the next couple of days. Are these bags OK for towing?
Also, How difficult is it to install the Arnott compressor? I've already bought that too.
I've also bought rear Bilstein Shocks for the rear as well. (passenger one leaked out oil)
So expect everything will be nice a tight.
Also, should I buy from FCP Euro that sells for $170 each or from rockauto that sells for $135. In either case, if I have a problem, would I contact Arnott directly or go through the company I order from?
Kind regards and thanking you in advance.
If I had installed Arnott air springs in the rear and had them blow out, leaving me stranded while I waited for replacements to arrive, I'd post all over the place too.
I pulled the 100psi rating picture off Arnott's web site. The reasoning for why this is inadequate are given in the thread.
You can figure out if the Arnott compressor you bought is made in China or made by AMK. I own a brand new Arnott compressor awaiting installation, and I just ordered an AMK compressor and will sell the Arnott because - see the label - made in China. If you are willing to install a Chinesium compressor, you can get a perfectly functioning one for about $150; that's what I did, and the only real downside is it probably won't last more than about 20k miles - which is how long the Arnott compressor lasted. And no, I don't have any leaky air springs, at least not grossly so.
I wouldn't bother installing the Arnott compressor if it is Chinesium. Read the thread; I observed that some Arnott compressors are AMK; if you bought one of those, go ahead.
You can get an old stock Arnott AMK compressor on Amazon. P-2594.
Changing the compressor is only somewhat harder than changing the rear air springs.
If you insist on installing Arnott air springs in the rear, remove the crimp clamp and install a big stainless steel hose clamp. That might void the warranty, so maybe put the hose clamp on top of the crimped band. I don't know if that would work. The air spring material itself is probably more than strong enough, but the crimp clamp is apparently the weak link. Again, read the thread.
Finally, a gentle recommendation: Don't fiddle around with fonts, italics, and so forth. Just write.
Best of luck.
Best of luck.
Best of luck.
Sorry Eric, corrected. I meat to write "Bilstein bags (which I'm now considering)".
The bags aren't expensive. You could get a pair of Bilsteins and keep them in the truck with you when you tow. That and a floor jack - and if you end up with a blown-out Arnott bag, swap the Bilstein in until you get home and the Arnott replacement arrives.
Honestly, none of the suspension products, short of Chinesium, are likely to have actual defects. The warranty is against normal wear - you're lucky to get 60K miles out of them - and, in Arnott's case, being under-designed. I would put Bilsteins on the rear and just put up with the lack of free replacement when they wear out. Or I would put a big hose clamp to replace or supplement the crimp clamp on the Arnott.
Or carry with you a pair of Bilstein air bags, using them to get you home, inflicting the wear on the Arnotts. Or swap in the Bilsteins when you have to tow, leaving the Arnotts to absorb the non towing everyday mileage. If you are determined to enjoy the warranty, I would pick one of these two options, depending on how frequently you tow and your tolerance for doing repairs by the side of the road.
Install a Chinesium, Arnott or otherwise, compressor because you don't mind having a non functional Airmatic while you wait for the Arnott replacement to arrive.
Whatever you do, avoid Chinesium valve blocks. The one I bought was non functional right out of the box. Not that one of the valves didn't work; as far as I could tell, none of them worked!
