GL 320 Issues - After turbo - Swirl flap motor install
The codes it is sending now are P0245, P2009, P0489, P0111, P1111, P1100, P0100. I have checked for leaks and found none. Does anyone have any idea what would cause the turbo actuator not to move at all?
I even put another actuator in and nothing, plug seams to have power and signal? I ordered a new MAF for one of the codes but it has not arrived. Any help where to start would be great. It better not be the brand new swirl flap motor. The only other thing we have not done is clean the EGR.
ANY HELP PLEASE I BEG!!!
The copper piece in the PCV line can ground out when you're moving things around, that would pop the fuse. Sorry, can't recall which fuse but I think it is 10 or 15 A.
Look in the front fuse box, in engine compartment.
That was it thank you so much. I had checked it before we had done the work but not after. You are a life saver!
