when should we change the trans and diff oil? How much is reasonable cost?
should i be get the trans fluid and diff fluid done too? what mileage? wait till 100k miles?
Trans fluid every 40k, diff fluid is an easy DIY.
But do not ignore your leaking air suspension.
Pressurized air has a way of finding the easiest way out through the path of least resistance, which would be an older air bag with small tears and pinholes.
Since you have a 550 with ADS it is worth checking both struts and reusing them if there are no fluid leaks, and then replacing the air bags onto your existing struts.
If you have leaky shocks, look up bilstein or arnott rebuilt ADS struts that come with the airbag already installed - massive labor saver, but higher parts cost.
Having the car in only once to do that will save you labor in the long run.
If the rear bags are suspect change those too. That's about $350 and 15 minutes a side as a DIY.
Definitely get the trans and torque converter drained and a new filter. Again, it's basic maintenance that you should perform in order to get the truck baselined.
I always change air suspension components in pairs but I once replaced the fronts only to have the rears fail two weeks later....they basically fail on time. I replaced with Arnott which have lifetime guarantee.
