Are there Mercedes jack stand pads that fit into the side holes for stands,not a jack
I'm buying a couple of these in case I ever need to jack the car up on the side, as I have a few flat attachments I can use with my jack so this would sit flush:
But...my jack stands look like this: https://i5.walmartimages.com/asr/c35...b39be0270.jpeg and I never feel great placing them on the sides of the car in those jack points because it slightly dents them due to not having the correct insert/pads.
Do I need to buy jack stands that are round at the top, or is there an attachment for this that would work...cause I can't find it.
As is often the case, if you’re missing your mbs jack pads a 4” piece of 2x4 with the grain running perpendicular to the standard stand c-cup will suffice.
One thing I may try once I receive my pads with the rectangle insert is to place them on top of the jack stand c-cup pad (the lower pad in the picture). The top pad (round) is just for display purposes meant to represent the new ones I'd receive with the rectangle insert. Will have to jack the car up a few more inches but should be a snug fit and I think there is enough surface area between the top and middle pads together to not warrant any slipping concern.
I would certainly not feel safe doing that.
So the only true way for me to use the correct adaptor meant for the jack pads is a stand that has a round top and not these c-cups, yes?
Avoid putting pressure on any bushings directly with the stand or jack. You risk ruining them.
The more stacking of lifting pucks etc you do, you increase the risk of one of them sliding.
