Hard start and smell of fuel
My 2012 GL550 has become slow to start after sitting for more than a day. I feel it is something to do with the fuel pressure as it seems to prime and then run fine.
I have read to change the fuel filter since it has a valve in it. I don't see any gas on the ground under it, but do smell gas after bringing it home that goes away a day or 2 later.
Any ideas?
Any ideas?
Slow start is caused by either weak/discharged battery or a "bad" starter. If the fuel pump fail or has a clogged filter, the the engine will rotate but it won't start.
I had a similar issue. I replaced both fuel pump and sensor and later found that the starter was not providing the adequate torque. Sometimes the engine turn slow, sometimes it start instantly. After replacing the starter no more slow starts.
I had "intermittent" slow start for a while. The the fuel pump failed and got it replaced. The gas smell as well as a weird fault code (P0446 Evaporative Emission Control System Vent Control Circuit Malfunction) happened after replacing the pump. Shortly after that the level sensor failed. I guess that there was a loose vent line. After replacing the pump, the sensor and clearing the fault as well as the gas smell the slow start got worst. I got the starter tested and found that it did not meet the torque requirements. I got the starter replaced and problem solved.
So starter fixed fuel smell? Did you have the same issue on restarts within an hour of starting it for the first time for the day?
Mine doesn't seem to be intermittent. I know when it will be hard to start.
the fuel smell was fixed after replacing the sending unit. Before replacing the starter I has the same issue on restarts. I thought was the battery, but got the battery tested and found OK.
