Rough creep, poor acceleration
Hope all is well/safe. I have recently been having a rough creep (1st gear) at a stop light and low speeds. It also hesitates to accelerate when I press on the gas pedal. I also hear a road noise when ~45-50 mph, which I thought was tire noise. I had the tires balanced yesterday, the tires look fine according to the shop, but the noise is still there. The check engine light is also on (attached picture with codes).
1. Could it be a bad ignition coil?
-I changed all spark plugs 20k miles ago, but not the original coils.
2. Could it be a transmission/torque converter problem?
-I did have the fluid changed about 1.5 years ago.
I would greatly appreciate any suggestions. Thanks very much.
Another one, relative to code P0410 is the secondary air pump of the engine, it maybe bad or the catalyst is getting clogged, so its important to verify the secondary air pump, the auxiliary air intake change over valve, the canister pump valve and the canister, the bypass valve.
And finally, the error P0016 and P0017 are relative to the camshaft position sensor located un the upper front of the engine, in your case I think it is relative to the left side sensors of the engine.
Maybe the error P0410 is being promoted by the P0016, so start verifying those sensors.
I wish you luck in this repair.
Issue #2; if your driveability symptom occurs when warm, these codes aren’t causing it and so are not related.
I’m thinking torque converter shat a blade or your transfer case chain slipping.
check for any cracking in flex discs as well.
After driving for about half an hour, the CEL engine came back on. I already know there is an issue with the timing chain, because the dealer told me it was likely stretched when I went for a diagnosis three months ago. That is probably a separate issue, issue.
Thanks very much again.
Thanks much again.
Replacing the bad ignition coil.
