Replaced Crankshaft Position Sensor (CPS), but still does not start
Old Nov 22, 2021 | 01:37 AM
RA020824's Avatar
Old Nov 22, 2021 | 07:29 AM
chassis's Avatar
2017 GLE350 4MATIC
Replace the battery and go from there.
Old Nov 22, 2021 | 03:55 PM
RA020824's Avatar
Old Nov 22, 2021 | 08:45 PM
RA020824's Avatar
But then I also came by this post
Is there a way to detect if the problem is definitely the fuel pump or the ECU? I don't want to risk spending $200 for a fuel pump which is not refundable after being tested..
Old Nov 22, 2021 | 09:29 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
It's 99.99% the fuel pump. They all fail.
Old Nov 22, 2021 | 09:32 PM
RA020824's Avatar
Old Dec 2, 2021 | 03:00 AM
RA020824's Avatar
Old Dec 3, 2021 | 06:59 AM
eric_in_sd's Avatar
2007 GL450
Originally Posted by ams3401
Replacing the fuel pump assembly solved the issue. I also ordered the fuel filter but the sheet metal cap covering the filter assembly was gangbanged with silicon from factory so I didn't bother with it.
Thanks for the updates.
It seems like a fuel pressure test kit is a useful component of the MB owner's garage. Did you try yours out?
Old Dec 3, 2021 | 10:44 AM
RA020824's Avatar
Old Dec 3, 2021 | 03:57 PM
eric_in_sd's Avatar
2007 GL450
Yup the pressure was showing zero both at ignition and cranking. The kit I used was a rental from Autozone and it was very useful!
Good job. Sorry it was such a roundabout way for you.
Frankly I should have bought a fuel pressure test kit a long time ago. I guess I just could not believe the system does not report fuel pressure.
I ordered this one from Amazon. It appears comprehensive, so I figure I can make use of it on other vehicles should the need arise. There are a bunch on Amazon Warehouse Deals for $52. Considering I paid over a grand to have someone change my fuel pump, the diagnostic tool is cheap.
Amazon Amazon
Old Dec 3, 2021 | 05:49 PM
eric_in_sd's Avatar
2007 GL450
