2008 Mercedes GL450 EBV, ABS, ESP Inoperative message
I later found out that the bearing goes in a certain way, because it has the magnetic encoders chip in the bearing, unfortunately it wasn't until after I drove it that I realized what I did wrong, so I got a new bearing and replaced it again, still can't get it to go into Drive/Reverse even tho the dash shows the gear selector in Drive/Reverse, but it stays in neutral.
Im at my wits end with this, so what I'm asking is do I have to calibrate or reset anything (on top of clearing the codes) to get this back to normal?
Please help!!
If you’re positive you have the right bearing in the right way, clear all codes by yanking all electrical power for about 30 minutes and try again.
2) If above doesn't fix it, put the old speed sensor on and see if that fixes it. This is the second next easy thing to do. Are you able to confirm the signal from speed sensor and see if it matches from other speed sensors. You could have damaged the cable of speed sensor.
3) Are you sure you put the magnetic/black strip side of bearing towards speed sensor? If you did, then the magnetic reluctor might be bad.
I just did my rear right bearing 3 days ago and didn't get any of these problems.
I've disconnected the main and auxiliary battery overnight thinking it would reset but when I connected them again it seemed like it never lost power the trip odo.was still the same even.
I've done my rear bearings not too long ago and didn't have an issue at all, just plug and play.
And I don't understand how I disconnected the main battery and auxiliary battery overnight yet it seemed like it never lost power.
I gonna disconnect them again for an hour and try to get all the excess power out
I'm told the "Intelligent Servo Module" is probably bad, but if it was fine before I did the bearing how could it have gone bad now?
It was drivable for a couple miles before this happened, granted the ABS light was on due to sensor not getting a signal. But it's like it drove, the ABS light came on, then went into some sort of failsafe mode.
This is outside my knowledge, so bear in mind I am pretty much guessing. It sounds like the ISM is in a sort of corrupted state, half working, half not. Possibly resetting it, resetting the adaptations, would help.
Thank you all for the info and help!
I have yet to get this thing moving but I will get eventually!! I truly believe this is something minor and simple to fix just haven't found out how.
What do you get when you search all the modules for DTC's? Try that, noting, copying, or photographing everything that comes up. There will be tons of old stuff.
Then clear everything, make the problem recur, and see what comes up.
Things like this is what discourages me from buying a Benz.. I love how they drive, the way they look, but high maintenance come with high class.
Lets try this.
Take off the ABS relay from front fuse box under the hood. In an otherwise normal GL, it would disable ABS, ESP, Power steering and push the car into limp mode. Then see if you can put the car into drive. If you can, take it for a ride around the block. It won't go more then 2nd or 3rd gear. Then come back, park, (at this point you may also do additional step to disconnect both batteries and touch terminal together) and put the relay back. Start the car and hope for the best.
What I am hoping is that, this would force the system to think that ABS system is shot and it has to abort the test, and go into limp mode.
https://mbworld.org/forums/gl-class-...ml#post6823657
Good Luck.
It is practically anti-robust; if it encounters an error, instead of attempting to work around it, and inform the operator what happened, it just gives up. It is simple software, designed to accommodate well a system that is running, but with little in the way of mechanisms to handle possible problems.
Do let us know what happens with the suggestion below. As an alternative, there ought to be some way of resetting the module that thinks you are stuck doing the test. Since you are stuck, explore the "Variant Coding" of the pertinent modules, TCM, ABS. I don't even know what is available there, but maybe you will find something.
Lets try this.
Good Luck.
Lets try this.
Good Luck.
I Did find out that the Snap On scanners I have can't read 100% of Mercedes systems. So I ordered one on Amazon specifically for Mercedes and I have gotten a bit further with it. I'm now getting these codesC103 - Stored(Event) - No CAN message was received from control unit N1 5/5 (Electric selector lever module (ESM [EWM])).
1709 - Stored(Event) - The actuator motor in component A80 (Intelligent Servo Module for direct select) cannot reach it's specified target position.
2805 - Stored - The signals from the selection range sensor are implausible in comparison with the signals from the ISM.
I just pulled these codes as I was replying back to the forum. I'm still studying these codes. Hopefully this new scan tool pays off 🤞🤞
I wonder if you can interrogate the ism in real time while making gear selections to rule out or in a failing shifter or bad connection to it. You’d be looking for shifter position mismatch to what you’re physically doing with it.
conversely a bad ism would report a position not in line with what the selector lever and your mark 1 tactile hand feel is reporting.
Now that you have written down those errors, consider clearing them. The higher level tools only clear the OBD stuff. With them cleared, you can do as Max suggested and see when they recur.
We have several guys shopping for scan tools. Could you reply with what you bought, and your observations so far?
I cleared the codes, in the ESP menu code 5410 came back which is "Road test active"
In the AGW Audio Gateway menu codes U1102 and U1101 have come back, but I'm pretty sure those are unrelated.
ISM Menu doesn't have any codes coming back.
I was kinda being cheap with it but this is the one I ended up getting. It was fairly cheap, got it prime 2day shipping. So far it has proven it's worth to me lol. As I said before, I was able to finally read more data and pull more codes, simple to use and even came with a micro SD, USB thumb drive and charger.
Im also able to shift to neutral with the scanner, it did successfully.
now thru the ISM live Data menu when I shift out of Park, but the scanner still shows it's in Park. But it will shift into neutral with the scanner thru the same menu different function
Maybe with this tool you can poke into the ESP module and abort the test. You need to explore the modules with your tool anyway.
Or do as Max suggested = unplug the ABS relay and try not to hit anything in your neighborhood.
