Problems after Replacing the battery
Old Jan 7, 2023 | 08:24 PM
Car_uy's Avatar
GL 450 (2008)
Exclamation Problems after Replacing the battery
I have a (2008)GL 450 that we picked up days ago, but i didn't check on anything before we replaced the battery. After replacing the battery 2 noticed 2 issues.
1. the radio is not working. I cannot turn the knob for volume as it doesn't not work, and i cannot press the buttons on the steering.
2. The phone/blue tooth device does not work. When i insert it into the Slot. It does not flash blue. No lights turn on. The "Tel" option states "not available" and i have no idea what i could possibly do about that.
Additionally, the car states that the break light is malfunctioning, but that isn't the case as we have tested it. We assume this occured after replacing the battery, we even unpluged the aux battery to replace that one as it is old, but came back empty handed on our search.
Old Jan 7, 2023 | 09:30 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the GL. Try posting the question in the X164 section where owners will see it and make suggestions.
Old Jan 7, 2023 | 10:13 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to X164 forum...
Old Jan 9, 2023 | 11:16 PM
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
Did you disconnect both batteries at the same time? If yes, that's the issue. You may need STAR to reinitiate the modules.
Old Jan 12, 2023 | 07:44 AM
Car_uy's Avatar
GL 450 (2008)
Yes we did disconnect both of them. What is STAR?
Old Jan 12, 2023 | 08:25 AM
W205C43PFL's Avatar
The proprietary diagnostic system Mercedes uses for your GL.
Old Jan 12, 2023 | 08:29 AM
Max Blast's Avatar
NGL450 w/EORP, S550
After replacing battery, did you check all circuit breakers?
Old Jan 12, 2023 | 11:13 AM
Car_uy's Avatar
GL 450 (2008)
No?
Old Jan 12, 2023 | 11:15 AM
Car_uy's Avatar
GL 450 (2008)
will I have to take it an Mercedes dealer for that?
The car is rather old I don’t even know if it has warranty on it.
Old Jan 12, 2023 | 11:18 AM
W205C43PFL's Avatar
not really, there are independent shops that have this system, they either licensed it from MBUSA or have it from another way. Don't pay dealership rates.
Old Jan 12, 2023 | 05:12 PM
Max Blast's Avatar
NGL450 w/EORP, S550
ok. Any trip to the dealer for this problem is going to be 2 to 300 bucks plus.
check all circuit breakers first.
Old Mar 20, 2023 | 04:27 PM
Car_uy's Avatar
GL 450 (2008)
I'm sorry its about 2 months late but where can I find these circuit breakers?
Old Mar 20, 2023 | 07:21 PM
W205C43PFL's Avatar
If I recalled correctly, there is one under the hood for the GL and under the floor cover near the tailgate, hopefully someone has the actual diagram showing the locations of them.
Old Mar 21, 2023 | 12:56 AM
DLB_Adelaide's Avatar
GL320 X164 OM642 722.902
Sorry to hijack the thread.
Will this be the same scenario with a w164? I know w164 is a different beast to the x164. I just replaced the auxiliary batteries on my w164 and did not notice any problems. Both batteries disconnected simultaneously.
Old Mar 21, 2023 | 01:36 PM
texas008's Avatar
2007 GL450
for my 2007 GL450 (115k miles), I've replaced the two batteries all together two rounds.
in both cases, there is a brief moment that both batteries are removed from the SUV.
did not cause any problem
Old Mar 21, 2023 | 03:14 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
No problems here either. IIRC, you have to remove the main battery to replace the Aux battery, so it is unavoidable. There aren't circuit breakers for the stereo, just fuses. Fuse chart
Old Mar 21, 2023 | 04:07 PM
Mate! That electrical fuse map is gold! Useful information for diagnostic
