GL450 starter motor replacement quote from dealer.
If you're unable to replace the starter yourself, take the car to a good indy shop. They'll be cheaper.
When it has the long crank, is it cranking slow?
A long crank when fast can be due to varnish on the intake valves making them stick when cold. Make sure you are using Top Tier gasoline, or pouring a bottle of Regane Complete in the tank once in a while.
It has 112k miles, mostly short trips. probably its time for new starter motor. 99% of time its using the Sam's Club 93 gasoline.
will perform the engine cleaning and start shopping for the starter motor. either FCP or Rockauto.
But brace yourself for the long crank not fixing the problem. You might check to see whether the Sam's gas is Top Tier.
I prefer to get cheap gas from high volume stations, so I go to Autozone and pick up Regane Complete. The research was not trivial, having to look at the Safety Data Sheets, but that is the product which I concluded had the best value for PEA, which is the ingredient in Techron.
If you buy over $20 at a time at Autozone, you get a freebie after five purchases. I get three bottles at $7.49 each.
Pricing on the fuel additives is all over the map. Basically they contain PEA and/or naphtha, with no apparent connection between quantity and price.
If in fact your valves are sticking due to varnish, it will take some time for the additives to clean off the varnish. I had to run a couple of tanks.
If you have a bidirectional tool, such as the Autel MP808 or DAS, you can run the "compression test" when the motor is cold. Uneven cold compression can be due to sticking valves.
for that job, that’s a steal. Would have took me all day and lots of busted knuckles and vertebrae.
