Suspension Torque specs
Old Feb 13, 2023 | 12:57 PM
r63wannabe's Avatar
2011 GL550
Hey all, I’m swapping the front air suspension with factory replacements, Bilstein.
I am also do the sway bar bushings, and sway bar links.
Does anyone have the torque specs for the strut mount, the bolt connecting the strut to the lower control arm, the sway bar links, and bushings?
I’m not wanting to over tighten and strip anything.
Thanks I’m advance!!!
Old Feb 13, 2023 | 05:40 PM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
PM or post your VIN. I can look it up in WIS
Old Feb 13, 2023 | 06:29 PM
eric_in_sd's Avatar
2007 GL450
They are big steel bolts going into big steel nuts. I never bothered with any specific torque specs. Just yank 'em gutentite.
Old Feb 13, 2023 | 10:07 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Pull whatcha got.
after the car is sitting flat on the deck, of course.
Old Feb 14, 2023 | 08:35 AM
eric_in_sd's Avatar
2007 GL450
I don't think that is necessary for strut replacement.
However, if you keep the clamps tight on the swaybar, yes those bolts must be tightened at ride height.
Old Feb 14, 2023 | 03:33 PM
DarthVaderpa's Avatar
X166 GL550
Check the attached document
Old Feb 15, 2023 | 10:12 AM
atraudes's Avatar
Sorry it took a while. Looks like DarthVaderpa has you covered for the strut, but jic here's the docs for your VIN. Let me know if you need any others.
Old Feb 26, 2023 | 08:41 PM
r63wannabe's Avatar
2011 GL550
@DarthVaderpa @atraudes thanks a million! That's everything I need to get this done!!!!
Old Aug 13, 2025 | 07:30 PM
S550TK's Avatar
08' S550, 19' GLS450
I had a quick question. Do any of the bolts have to be torqued down while the car is at ride height?
Old Aug 14, 2025 | 01:05 PM
texas008's Avatar
2007 GL450
yes. use another floor jack to push up the brake rotor to normal ride height.
Old Aug 15, 2025 | 01:12 AM
S550TK's Avatar
Do I need to do this for all the nuts and bolts or only some of them?
Old Aug 15, 2025 | 10:20 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
It's for bushings that rotate. This is generally the bolts on the frame, not the steering knuckle. Not needed for ball joints. Almost for anywhere where the bolt is horizontal vs vertical. Look up "properly clocking" control arms. There's some good videos explaining in YouTube.
