Another Suspension malfunction light
I had Airtmatic malfunction due to the weak compressor ran over the time setting limit ( 25 or 35 sec???..forgot the code too).
I wish it was whole
I wish it was whole
PS, the 100 bill piece I found was counterfeit, I thought that it didn't feel right, too thick.
Compressor cooling off message is generally the clue that it’s worn out from pressuring leaky bags, but in your case you’ve already replaced the front struts and the compressor. I’d take a look at the connections you made there.
what kinds of parts did you put back in it? OEM or counterfeit?😃
I also got a code saying I had a leak but that may have been because the comp couldn't get up to proper pressure.
Any thoughts on that??
You don't actually have to take the front bumper cover off. Just take off the fender liner and maybe the engine belly pan.
Get used to taking off the fender liner. Doing so brings many seemingly insurmountable tasks within reach.
But at this point, just cut your losses and get rid of the thing with full disclosure.
