Airmatic Compressor Question '11 GL450
Old Mar 31, 2023 | 08:51 AM
Josh Ehmer's Avatar
2011 GL450
Can the airmatic compressor pump up 3 out of the 4 airbags? I have replaced my right rear airbag twice within the past month and it doesn't inflate that corner only. Are there separate fuses for each wheel or corner of the car? When I press the raise suspension button all except r-rear inflate and sometimes it gives me a "level selection not permitted" error (see pic). This issue is totally jacking up my ABS and traction control in the L-front (I replaced that speed sensor, no change).
My next step is to replace the ride height leveling sensor in that corner, but is there a way to test it first? Any help is appreciated.
Last edited by Josh Ehmer; Mar 31, 2023 at 06:24 PM. Reason: The picture is not the issue, please read.
Old Mar 31, 2023 | 09:33 AM
EmilyMB's Avatar
gl550
Looks like driving over 35mph…
is it error under 35mph?
Old Mar 31, 2023 | 10:52 AM
91stealthes's Avatar
2012 GL350
Correct. You cannot raise the vehicle going over 40 mph.
Also, if the vehicle is in the raised positions, the vehicle will also automatically return to normal ride hide when you travel at 40 mph or above for a short time.
Old Mar 31, 2023 | 11:20 AM
Josh Ehmer's Avatar
2011 GL450
Went over 30 to get the warning.
I went over 30 to get the warning light. Sometimes it does it sitting still.
Old Mar 31, 2023 | 05:24 PM
eric_in_sd's Avatar
2007 GL450
I would guess you either have a failed valve on the valve block or the control module has been compromised. Although if the latter, it more likely would not work at all.
Old Mar 31, 2023 | 05:37 PM
Max Blast's Avatar
NGL450 w/EORP, S550
yeah, you can’t raise the vehicle over 30 so that is normal. But if the right rear isn’t coming off when it does race under 30 if then you may have a failed level sensor there, or a clogged orifice in the valve body to that wheel.
it isn’t the compressor that raises the vehicle. That is done by stored air pressure in the central Reservoir, which is being redirected by the valve block to each individual wheel that needs it. All the compressor does is replenish the central, Reservoir through a connection in the valve block when commanded to do so.
Eric now is the time for your awesome diagram.
Old Apr 1, 2023 | 07:30 PM
eric_in_sd's Avatar
2007 GL450
(bows humbly)
The valves on the valve block are electrically activated. If you raise three corners but not the fourth, in all likelihood either that valve, or the control module, has failed.
If you have a bidirectional scan tool, such as Autel MP808 or MB STAR you issue a command to read the individual component pressures; the system does this by actuating one of the valves, which you hear as a click.
Old Apr 1, 2023 | 09:03 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Originally Posted by eric_in_sd
(bows humbly)
point of order, the line from the filter to the compressor is more of a gentle arc, following the curvature of the wheel well.
Old Apr 2, 2023 | 08:21 AM
eric_in_sd's Avatar
2007 GL450
Hahaha that's what I love about doing things in Paint. The crudity invokes a sort of Art Brut paradoxical elegance.
