Rear air bags
Rear air bags
Hi, just a question I recently changed my left rear airbag with bilstein. At the time the other side was fine now the right side is dropping. Why is that? I only changed them 3 years ago. The new air shock was installed last week. My truck is a GL450 2012
Arnott rear airbag is about $150 each at rockauto.com, they last about 6 year 50k miles on my GL450.
It is pretty easy to replace the rear airbags DIY. or a mobile mechanic or indy shop might charge $90 each to replace the rear airbag.
2010 ML550 VIN WDC1641722A564750, 2010 B180
Look also at FCP Euro in addition to Rock Auto as mentioned. $1,100 for two rear bags sounds VERY expensive. They are DIY and would take a novice mechanic about 45 minutes each side (that's what it took me). A professional with a hoist could probably do both within 45 minutes.
Max Blast (05-19-2023)
We’re making a whole lot of assumptions here, but if OP is of sound body and reasonable mind this is a DIY done with a jack and two jack stands in a driveway in about 45 minutes a side, plus parts cost of ~$300 ish.
(if you don’t run into compound problems such as prior owners or mechanic having cut the air lines short)
plus there is unclear language as to if the $1100 is for the one remaining rear airbag (highway robbery) or the remaining three (not so bad)
The fronts are also diy if you replace the whole strut. If not, it gets advanced.
BlackML550 (05-19-2023)
Received 1,084 Likes
E55, GLS450, GL63, GLE350
Took me around 15 minutes per side and that was the first time I had done the work. It's probably the easiest DIY on the GL other than changing the taillight bulbs.
