2008 GL 320 CDI Rear Suspension Airbag Bursts
On my 08 GL 320 CDI we replaced the rear suspension with Arnott bags which I have always had good luck with.
Right away the driver's side one burst when the car came down off the lift. We assumed it was a defect. Replaced it, this one burst as well. The third one lasted a day or two then burst. This is not a defect, something is causing it to burst.
Has anyone encountered this? It appears to split up the back. I am wondering f the lower control arm in the rear is possibly bent and when it actuates it is twisting the airbag causing it to fail. Really pulling our hair out with this one - any advice greatly appreciated.
Thanks,
Matt
Was it popping air springs before? Have you asked Arnott what they think? You are not having a problem with the passenger side spring? Swap it to the driver side and see if it goes bang.
The car was exhibiting other symptoms previously - there was an unexplained major sway in the rear end when driving. Felt like the rear end would waggle while driving.
I haven't heard from Arnott - will ask the shop if they have communicated with them.
Passenger side spring seems OK. I wondered about asking if they had swapped the spring across to the other side. The issue I guess I am worrying about with this plan is these things are $500 each and if it pops another one I am not sure I can afford to keep replacing them.
i subscribe to the over inflation theory. When it bursts, is that corner higher than the others?
something is telling the valve block to let more air into it, and that usually is the level sensor.
yiu can visually inspect it to see if it is overtraveled and also read it out with an mb compatible scan tool to see if the signal it’s putting out is noticeably different that the other three.
if it isn’t any of the above the next culprit is a seized or leaky valve block
These are all good ideas and I will ask about all these points. I have been working with this shop for years and know that they are honest. I do share your concerns though that they don't seem to have an answer except to develop a workaround.
Checking the pressures is a little tricky; you need a bidirectional tool that will send instructions, because it has to open the particular spring's valve to read the pressure. The pressure sensor is on the valve block manifold.
To my knowledge, the system does not check pressures on the springs. It only monitors the reservoir pressure, particularly when refilling the reservoir.
