2007 GL450 radiator replacement tips
Old Nov 28, 2023 | 10:42 AM
texas008's Avatar
2007 GL450
Radiator replacement for some other cars e.g. Toyota, Lexus, is pretty simple and straight forward.
For GL450, what makes this job intimidating are the following two factors
1. front bumper needs to be removed, its just a extra step, takes some time,
2. power steering cooler line connections, and transmission cooler line connections. those are special connections and can be confusing at first sight.
other than that, it's just a radiator replacement at the end of the day.
Old Nov 29, 2023 | 08:11 AM
eric_in_sd's Avatar
2007 GL450
Dude it only takes an hour if you're competent.
The only reason you have to pull the bumper is to remove certain bolts on the underside. I did not replace those bolts. In fact, I did not replace about 40% of the plastic shroud routing air into the radiator, aerospace style. The engineers were fantasizing this is a F1 machine.
Take your time.
Do you have stubby flex head wrenches? I recall you need them for the lower bolts. I assume you have the WIS procedure. Past that it's mostly just setting aside a day or two and getting to work.
Old Nov 29, 2023 | 08:58 AM
texas008's Avatar
2007 GL450
Thanks for the tips. yes i have some stubby flex head wrenches. do not have the WIS procedure. learned about the procedure/steps from several Youtube videos.
Old Nov 29, 2023 | 10:51 AM
eric_in_sd's Avatar
2007 GL450
You can buy a bootleg WIS on Ebay for five bucks. The only downside is it needs 100+GB of drive space to store files, and needs lots of RAM to set up a virtual machine. Highly recommended, though.
Old Dec 1, 2023 | 07:28 PM
Sallad's Avatar
Veteran: Army
Veteran: Canadian Forces
08 GL320 CDI
What is that?? I tried googling, but got a bunch of odd results.
Old Dec 1, 2023 | 09:16 PM
eric_in_sd's Avatar
2007 GL450
WIS stands for Workshop Information System. It gives you full diagnosis and repair procedures for every MB ever made.
Old Dec 2, 2023 | 06:38 PM
Sallad's Avatar
Veteran: Army
08 GL320 CDI
Oh I see, thanks. Sort of like the Bentley manual for an Audi/VW.
Old Dec 2, 2023 | 07:40 PM
eric_in_sd's Avatar
2007 GL450
It is difficult to use, requires system resources like mad, and sometimes contains errors, but in general it is useful. I don't regret the $fivebux.
