Sounded like a drive shaft scraping the ground then it lurched 3 times
I did a scan with my Icarsoft MBIII and got these fault numbers
9010 The voltage was less than 9. O V durung 5 s
9036 Undervoltage detection. Undervoltage is not detected until after 5 s and a voltage of <9.5 v
9030 under voltage detection undervoltage is not detected until after 5 s and a voltage of <9.5 v
C361 local undervoltage at circuit 30 (voltage 9.5 v)
9128 supply voltage of the Control Unit is Too Low (undervoltage)
A10A00 the power supply in the system is too low.
Could any of these codes make the truck have a scraping sound and lurch three times.
Could the problem be in one of the codes/faults?
Anyone else ever had this problem?
get under the car and find the damage from the piece of metal you picked up and dragged a few hundred feet that one time a few weeks ago.
those codes you posted are unrelated to that event and point more towards a low voltage event caused by a failing or momentarily disconnected battery.
I recently change the rear brakes and rotors. Akebono brand. Could it be that my rear shoes and rotors grabbed and made the scraping noise, released and grabbed a couple of times to cause the lurching?
Probable? Possible?
I can't imagine brakes making that noise?
Excessive scoring of a rotor or broken or missing hardware could be the witness marks of the sensation you’re describing.
Get eyes on it.
about the only thing I can think of that would cause lurching or brakes grabbing is a failing wheel speed sensor that triggers ABS at random low speeds. The noise could probably be a loose brake shield.
id have the car read out with a proper MB scan tool to look further into any of these low voltage events having burned out a wheel speed sensor - somehow, they don’t like it when a new battery is applied - the text you’re looking for is “xxxx wheel speed implausible signal”
Any of the small parts around the brakes wouldn't make such a big noise or cause "lurching"... "dragging", yes, but doubtful on the lurching. I suppose anything's possible and it's easy enough to pull a wheel and check.
Lurching sounds more tranny related. POSSIBLY the low voltage caused issues at the tranny. Look up a better definition of those codes -- what is: circuit 30, control unit and system -- what "system", etc?
Go to a parking lot - get some speed and stomp on the brakes to activate the ABS (wet ground would be easier). Is this the sound you heard?
The wheel speed sensor is in a different location. It senses the rotation of the wheel bearing.
