2011 GL 350
Old Mar 1, 2024 | 11:19 AM
Javi's GL 350's Avatar
Mercedes-Benz GL Class GL 350
2011 GL 350
Hello I have a 2011 MB GL 350 Blue Tec withb109k miles. The issue I'm having I believe is something electrical or system miscommunication. Out of no where the information cluster goes crazy it lights up like a Christmas tree flash all different signals on and off like ABS, ESP, Pre safe operative, Brake lights, Malfunction, SRS light, Check Engine light, Wipers start going off, RPM needle starts jumping up and down,. Then The car will not want to shift into neutral or park or reverse. I just have to turn it off. Then it won't turn on for a while. And then when it does turn back on it's like as if nothing ever happened.
any advice on what can be the issue? Took to dealership and they were no help.
Old Mar 1, 2024 | 12:10 PM
DennisG01's Avatar
'08 GL 320 CDI
What did they check/verify at the dealership?
Could be things like a failing battery, bad/corroded connections (at the battery or underhood, including grounds), SAM, etc.
Old Mar 1, 2024 | 12:43 PM
eric_in_sd's Avatar
2007 GL450
Did you leave it out in the rain?
Old Mar 1, 2024 | 05:07 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Look for water under the drivers seat, well, or the battery well under the passenger seat. This smells like a front Sam frying.
Old Mar 18, 2024 | 10:46 AM
Dealership found nothing only recommended to change the battery which they did, the only reason battery died was because the the light on dash will not turn off
Old Mar 18, 2024 | 10:48 AM
battery well, post and connection are clean and dry.
Old Mar 18, 2024 | 01:35 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
Rear Sam Unit.
I would start with the rear Sam unit. Open up your rear hatch and on the passenger side remove the fuse door. Reach under and feel for water or dampness.. the rear taillights can leak. If you feel dampness .. disconnect the battery and tear into the Rear Sam looking for corrosion etc.
Old Mar 18, 2024 | 01:56 PM
DennisG01's Avatar
'08 GL 320 CDI
What "light on the dash won't turn off"? I didn't see that you mentioned that anywhere? The flashing/crazy light show is not the issue - that is the result of an issue.
Old Mar 18, 2024 | 04:01 PM
vesiadog's Avatar
Rear Sam relocate
Very interesting video. After all the rear Sam water corrosion problems .. here is an interesting post.
Here is a picture from the video.
Old Mar 18, 2024 | 04:15 PM
Max Blast's Avatar
NGL450 w/EORP, S550
There’s also well under the driver seat where all the sensitive electronics such as SAM-F live. Are they dry?
all the things you listed in your initial post are routed by the front Sam.
Old Mar 18, 2024 | 07:45 PM
vesiadog's Avatar
Location of Front Sam
On my 2008 GL under the Driver seat is the Radio Power Amp and definitely a strong possibility of water. My front Sam is near the battery under the passenger seat.
Old Mar 19, 2024 | 04:47 PM
Max Blast's Avatar
NGL450 w/EORP, S550
True, front Sam is under the passenger seat in an LHD vehicle.
But wait, there’s more under your driver seat - and it might not be the sam. It could be any and all of the modules or busbars that control power to all the units that are malfunctioning.
You say strong possibility of water, I would think there’s water there and those electronics are compromised.
Old Mar 19, 2024 | 04:53 PM
vesiadog's Avatar
Water under driver seat LHD
What I found after my Power Amp board went out was about an inch of water under the seat in the valley. Sure looked like the possibility of water spilling from cups in the center console IMO?
Old Mar 19, 2024 | 07:37 PM
Sallad's Avatar
Veteran: Army
Veteran: Canadian Forces
08 GL320 CDI
What kind of statement is that? It's a vehicle, they get left out in the rain all the time?!?
Old Mar 19, 2024 | 08:14 PM
vesiadog's Avatar
Rain
Relax I think Eric gets left out in the rain a lot!
Old Mar 29, 2024 | 01:01 AM
yes
Old Mar 29, 2024 | 01:03 AM
yes
Old Mar 29, 2024 | 02:05 AM
Max Blast's Avatar
NGL450 w/EORP, S550
some people garage their benzes and don’t drive them in the rain, if you are to believe the average Facebook marketplace ad for a rotten r107 that “just needs a fuel pump or new battery not sure”.
Old Mar 29, 2024 | 10:08 AM
eric_in_sd's Avatar
2007 GL450
Yes, one would think. Especially a Gelandewagen.
There are apparently four vulnerable points: Roof rack mounts, sunroof seals and drains, panoramic roof seals, and taillight seals.
