Ecu replacement
Old May 31, 2024 | 11:57 PM
jemison60's Avatar
GL 450
Ecu replacement
Can I find an aftermarket ecu or remanufacturer fo mu GL 450; 2008
Old Jun 1, 2024 | 12:09 AM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
Ebay ECU
I have never replaced one but I see them on ebay all the time . Hopefully some members here can tell you if and how they need programmed. Good luck.
Also checkout rebuilding/testing places like this one.
https://the-ecu-pro.com/
Old Jun 1, 2024 | 12:23 AM
jemison60's Avatar
GL 450
Ecm replacement and programming near new orleans
Hey Guys I am lost, had professional diagnostic on my 08 GL 450
I was told that ECM replacement and programming is required
Estimate $4000
Need help
Old Jun 1, 2024 | 12:28 AM
jemison60's Avatar
GL 450
Thanks checking ecu plug n play rebuild site
Old Jun 1, 2024 | 12:30 AM
vesiadog's Avatar
reviews
Make sure you do lots of reading and reviews. They are NOT plug and play. They will have to be programmed to your car.
Is the ECU partially alive or completely dead?
Old Jun 1, 2024 | 12:39 AM
jemison60's Avatar
GL 450
Ecm not communicating at all won’t crank at all
Old Jun 1, 2024 | 08:02 AM
eric_in_sd's Avatar
2007 GL450
There are many places that will set up an ECU for you. I changed my ECU. PresserTech helped me.
It has to be VIN coded to the vehicle and also has to be configured to match the vehicle's configuration. This can be done with removing the EEPROM from your ECU and installing it in the new one, or it can be done semi manually.
It will cost you about $1000.
Old Jun 1, 2024 | 12:53 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Or if you have a star system with developer mode to code vin and configuration into ME9.7 the cost is only the part. I am surprised that not more of these ecus get fried on a regular basis seeing as it’s sits right on top of the engine.
Old Jun 1, 2024 | 02:25 PM
vesiadog's Avatar
Brilliant design
Especially with one of the parts always being replaced … the thermostat !
